Hi Robin2,
Well, as long as you are able to interpret, what I am saying.....
Yes, I can use the DPDT switch to successfully switch from the MPPT to the BMV and read its data, I do have to exit the the MPPT window first so that the Victron software can pick up the BMV once that happens I can click on the BMV Icon and then view its data.
Your interpretation is 100% correct!
The code that works.
#include <SoftwareSerial.h>
SoftwareSerial Switch(3, 5);
// initialize both serial ports:
Serial.begin(19200);
Switch.begin(19200); // RX 3 TX 5
// read from port 1, send to port 0:
if (Switch.available()) {
int inByte = Switch.read();
Serial.write(inByte);
// read from port 0, send to port 1:
if (Serial.available()) {
int inByte = Serial.read();
Switch.write(inByte);
Hope this helps.
Kind regards.
Charles.
