For the past week i have been using this HC-05 module with no problems.
Now i don't know what i have done but i can no longer connect to it.
(Connecting via a Bluetooth Terminal app. on Android phone keeps failing)
FWIW : the "event" that preceded this communication failure was running a program that inadvertently looped through a println
multiple times with "no available display resource" - i could sense the Bluetooth Terminal app. starting to seize - incoming "data flood" (???) and it hanged several times meaning i was unable to input a key/char (to send to the Arduino).
Also - i had a LED voltage indicator on the power-rails and i now remember, it spiked to 5.01 V while the app seized. Then again, it's possible it was just the motors drawing current incessantly - it's basically a BT-remote controlling a vehicle via 'w,s,a,d'.
Don't know whether it's possible the HC-05 module got fried - but the LED is still blinking waiting for pairing and it is a detectable device - just "unconnectable".
Can anyone suggest what steps to take to find out what has gone wrong ?
BabyGeezer:
Don't know whether it's possible the HC-05 module got fried .
If there is nothing to suggest that Arduino is fried, and the wiring to Bluetooth is correct and unchanged, and your phone is kosher, it probably has
Nick_Pyner:
well, that's sad to hear.
so, what i described as the "event" is theoretically possible ?
and that it wasn't making up some scenario from dodgy electronics knowledge ?
even if it's fried, it can still run the indicator LEDs ?
is there really no other tinkering i could do just to be sure before trashing it ?
Nothing you describe sounds fatal to bluetooth, hence my comment.
I suppose "two weeks......with no problems" could mean that you now have flat batteries, but HC-05 can run on 3.6v so I doubt the problem lies there.
Your first, last, and most obvious test is to run a hello programme, with a known good phone, with Arduino out of the car, with everything else disconnected, and using a proper wall wart for power.
looks like i have to get a new one then
i tried the most basic ;
digitalWrite(13,HIGH);
Serial.println("Hello world!");
digitalWrite(13,LOW);
delay(2000);
with every thing disconnected but the RX0,TX1 and a known power source.
i haven't verified the phone though - that can Receive a file from the PC, but this new Windows doesn't have the old HyperTerminal to test Serial communication and i can't get it to lock on to a COM port for the Bluetooth dongle. (which means i can't use the PC to test the HC-05 either !)
talk about barebones hardware...
thanks for all your input then.
Cheers.
Nick_Pyner:
RealTerm should suffice
Thanks, will give that a go.
