Hardware
Need help robot preject with 24 small (3vdc) motors. They need to go forwards and backwards and move individually via a bluetooth user signal. What Arduino hardware combination would best fit this project?
Welcome to the forum.
http://forum.arduino.cc/index.php/topic,148850.0.html
Thanks.. Tom.. :slight_smile:
PALADIN:
We need more information. Assuming you need speed and direction control for each motor you will have difficulty even with a single Arduino Mega as it can only produce 12 PWM signals. You will also need to choose your motor drivers carefully as, for example the Pololu DRV8833 (with which I am familar) requires a PWM pin for each directon. If you can find a low voltage driver that only needs one PWM input coupled with digital pins for direction then you will get better use from the limited number of PWM pins.
...R
I know the Ardino uno coupled with a power supply board will run 2 motors back and forth and are able to controll speed and not burn out the chip. Which Arduino runs the most pins or what combination can i use torun 24 as previously posted. Im such a newb its been a while since i got my degree in this so i do have some basic understanding. If you are willing to talk on phone I am willing to pay for your time. Just want to get this done quickly.
PALADIN:
Did you read Reply #2?
...R
