Hi I want to use HardwareSerial() in my project y that wrote on esp32. part of my code is:
#include <HardwareSerial.h>
HardwareSerial mySerial(2);
but it doesn't compile and get this error:
no matching function for call to 'HardwareSerial::HardwareSerial()
Why exactly do you want to use the HardwareSerial library ?
Using an ESP32 you can define the pins to be used in the begin.function()
Serial2.begin(115200,SERIAL_8N1,14,15);
and then use Serial2 as normal
Where did you get the "HardwareSerial" library.
If you want to use the hardware uart on the ESP32 you do not need such a library.
This may help.
Tom....
HardwareSerial SerialTFMini( 1 );
HardwareSerial SerialBrain( 2 );
Setrup()
Serial.begin( SerialDataBits );
SerialBrain.begin( SerialDataBits );
SerialTFMini.begin( SerialDataBits, SERIAL_8N1, 27, 26 );
// Initialize the TFMini LIDAR
tfmini.begin(&SerialTFMini);
thanks for your solution.my problem is solved.
system
Closed
7
