Has anyone had success with Panasonic's PIR?
Hello,
I've stumbled across a PIR by Panasonic (Model EKMC1601112). I do not see much (if any) documentation. Not sure if this is a good or bad sign. Does anyone have any feedback or experience with it?
Thanks!
Got a link to a data sheet?
Yes Sir--
DATA SHEET:
https://www.mouser.com/datasheet/2/315/bltn_eng_vz-1371768.pdf
The specification "open collector output" should be enough information to get you started.
Leo..
const byte sensorPin = 2;
  pinMode(sensorPin, INPUT_PULLUP); // enable internal pull up
  if (digitalRead(sensorPin) == LOW)
    // do something
(See attached) Will this voltage be an issue?
That means you can power the sensor between 3 and 6volt (5volt is ok).
Page 3 says: Output: Digital (open collector).
Which means a switch to ground.
The output (switch) is (should be) independent of the power supply of the sensor.
Leo..
Thank you!
