Guys i need help. i want to try this hack using arduino ans old sony ericsson phone. Here is the link to the videohttp://www.youtube.com/watch?v=5tHlJLQvE1Y
Here is the code.
#include <SoftwareSerial.h> //Software Serial Port
#define RxD 7
#define TxD 8
#define pinOUT1 2
SoftwareSerial ericssonSerial(RxD,TxD);
String phonenum="XYXYXYXYXY";
String phonePDU="YXYXYXYXYX";
String OUT1ON="0C31D98C067A56A931D0D309";
String OUT1OFF="0D31D98C067A56A931D0D36804";
String OUT1FAIL="09CF2A35063206934C";
String OUT1ONOK="0ACF2A35067A3A41CF25";
String OUT1OFFOK="0BCF2A35067A1A8DA0E712";
pinMode(RxD, INPUT);
pinMode(TxD, OUTPUT);
pinMode(pinOUT1, OUTPUT);
ericssonSerial.begin(9600);
Init();
void Init(){
while (send_command("AT&F",500) != "&F\r\r\nOK\r\n") {
Serial.println("Modem reset...");
while (send_command("ATE=0",500) != "E=0\r\r\nOK\r\n") {
Serial.println("Echo Off...");
while (send_command("AT+CLIP=1",500) != "\r\nOK\r\n") {
Serial.println("Caller ID enabled...");
while (send_command("AT+CPMS=\"ME\"",500).indexOf("CPMS")==0) {
Serial.println("Phone Memory Selected for SMS...");
while (send_command("AT+CNMI=,1",500) != "\r\nOK\r\n") {
Serial.println("New SMS Indication Activated...");
Serial.println("Ready...");
String send_command(String at_cmd, int dly){
String msg;
char incomingByte;
ericssonSerial.println(at_cmd);
delay(dly);
while (ericssonSerial.available() > 0)
incomingByte = (ericssonSerial.read());
msg = msg + incomingByte;
//delay(1000);
return msg;
void sendSMS(String num,String txt){
String pduTxt;
int pduLength;
pduTxt="0011000C9103"+num+"0000AA"+txt;
pduLength=(pduTxt.length()-2)/2;
//Serial.println(pduTxt);
//Serial.println(pduLength);
ericssonSerial.print("AT+CMGS="+String(pduLength)+"\r");
delay(5000);
ericssonSerial.print(pduTxt);
delay(5000);
ericssonSerial.write(26);
char recvChar;
String recvStr;
int ringCount=0;
String incSMS=0;
while(1){
recvStr=0;
while (ericssonSerial.available()>0){
recvChar = ericssonSerial.read();
recvStr=recvStr+recvChar;
//Serial.print(recvChar);
if (recvStr.indexOf("CLIP")>0){
if (recvStr.indexOf(phonenum)>0) {
Serial.println(phonenum+" is calling...");
ringCount=ringCount+1;
recvStr=0;
//Serial.println(ringCount);
}else{
while (send_command("AT+CHUP",700) != "\r\nOK\r\n"){
Serial.println("Unauthorized caller..");
if (ringCount==2){
digitalWrite(pinOUT1,HIGH);
Serial.println("OUT1 ON...");
//delay(5000);
//digitalWrite(pinOUT1,LOW);
//Serial.println("LED OFF...");
ringCount=0;
Serial.println("Sending SMS <OUT1 ON OK>.....");
sendSMS(phonePDU, OUT1ONOK);
if (recvStr.indexOf("CMTI")>0){
Serial.println("SMS Received...");
ericssonSerial.println("AT+CMGR=1");
//delay(500);
if (recvStr.indexOf(phonePDU)>0){
//Serial.print(recvStr);
if (recvStr.indexOf(OUT1ON)>0){
ericssonSerial.println("AT+CMGD=1");
sendSMS(phonePDU,OUT1ONOK);
} else if (recvStr.indexOf(OUT1OFF)>0){
Serial.println("OUT1 OFF...");
Serial.println("Sending SMS <OUT1 OFF OK>.....");
sendSMS(phonePDU,OUT1OFFOK);
Serial.println("Invalid SMS...");
if (recvStr.indexOf("CMGS")>0){
Serial.println("Message Sent...");
while (Serial.available()){
recvChar = Serial.read();
ericssonSerial.print(recvChar);
I have tried uploading this code to my arduino and connecting the rx and tx pin and also ground.But nothing appears on my serial monitor... help me fix this code
