Has ayone used sure electronics hi power led driver with PWM?
I am having trouble using a sure electronics hi power led buck regulator with pwm from Arduino.
I am using the 300-3000ma buck regulator as seen http://store3.sure-electronics.com/ps-sp12153
If you have a clean no flashing/flickering of the led please let me know. I need to use this driver but I can not understand how to use pwm on it with no flicker.
Thanks
I have now got it workng and have the answer up on stack exchange where I had posted a different question but related to the same fading with this driver.
But the basic wiring is this
Why do you need to isolation?
It felt like the safest option for me with the different voltages and very high current.
How would you do it?
Connect GND to GND. Connect PWM pin to EN.
Using different voltages with shared ground is pretty common. And EN is an input and will not supply any voltage. So nothing weird or uncommon about it :slight_smile:
Thanks, I tried this and it worked fine.
One thing I did notice was the optocoupler stopped the LED lighting until it had a valid signal, unlike the direct connect.When the arduino was turned off or while booting the LED was on 100%.
Chris
That's because that's the default of the driver when noting is connected to the EN. Add a pull down or pull up resistor (depending on what level you want in rest) to the EN pin to fix that.
