hallo hallo hallo hallo hallo hallo
Honeywell ABP serie: https://sps.honeywell.com/us/en/products/sensing-and-iot/sensors/pressure-sensors/board-mount-pressure-sensors/basic-abp-series
ABPDANT015PGAA5:
ABP = Honeywell ABP serie
D = DIP package
AN = Single axial barbed port
T = liquid media
015PG = 0 ... 15 psi
A = analog output
A = 10% to 90% output range
5 = 5V sensor
Send the raw value to the Serial Monitor.
Serial.begin( 9600);
int rawADC = analogRead( A0);
Serial.println( rawADC);
delay( 250);
Can you show a photo with the flat corner of the sensor and tell what is connected to which pin ?
I think you have GND and 5V on one side, but I think that pin 1 = GND and pin 6 = 5V, so they can not be on the same side.
The goal is to get the sensor working. If you want to put that on a LCD display, that is the next step.
Your sensor is a type "AN":
Pin numbers:
pin 1 = the flat corner = GND
pin 2 = not connected
pin 3 = analog output to the Arduino board
pin 4 = not connected
pin 5 = not connected
pin 6 = 5V
That is not the same as you have.
@laura_in_action, your topic has been moved to a more suitable location on the forum. Introductory Tutorials is not for questions. Feel free to write a tutorial once you have mastered your problem
Note:
Please leave your original topic (and title) as is when your topic was solved. Now it will be difficult for others with the same problem.
