bonjour je veux que lorsque mon capteur detecte une distance =<10 une led s’allume jusqua la tout fonctionne trés bien mais je veux que lorsque la led s’allume mon haut parleur dise “Veuillez vider le bac marc”.mon problème c’est que direct après le téléversement la led est allumer en continue et le haut parleur répète en boucle la phrase.Alors que je veux que la led et le haut parleur fonctionne juste quand le capteur detecte une distance <= 10.
voici mon code:
#include "talkietz.h"
// Define various ADC prescaler
const unsigned char PS_16 = (1 << ADPS2);
const unsigned char PS_32 = (1 << ADPS2) | (1 << ADPS0);
const unsigned char PS_64 = (1 << ADPS2) | (1 << ADPS1);
const unsigned char PS_128 = (1 << ADPS2) | (1 << ADPS1) | (1 << ADPS0);
Talkie voice;
//Coller ci-dessous les définitions des chaines LPC des mots à prononcer
//veuillez
const uint8_t spW135224 [] PROGMEM ={0x00,0xB0,0xE6,0x2E,0x8D,0xD9,0xCC,0xCE,0x19,0xAA,0x74,0x63,0xF5,0x34,0xA7,0x4D,0x4A,0xDD,0x33,0x56,0x9D,0x26,0x73,0x0B,0x5F,0x6F,0x74,0x86,0xCA,0xD4,0xE4,0x6A,0xF1,0x19,0x06,0x27,0xD3,0xE9,0x99,0x6B,0x9A,0x98,0xD4,0x6B,0x46,0x8D,0x75,0x61,0xD2,0xCC,0x0E,0x35,0xB6,0xC3,0x49,0x2C,0x6A,0xD2,0x9A,0x37,0x23,0xF1,0xEC,0xD2,0x67,0x99,0x18,0x6D,0xA7,0x4A,0x9D,0xB5,0x23,0xAA,0xD9,0x36,0x7D,0xB6,0x86,0x39,0x77,0xDB,0xE4,0x39,0x3A,0x16,0xCB,0x9D,0x92,0xE7,0x58,0x9C,0xC5,0x7B,0x66,0xAE,0x73,0x50,0xD6,0xD8,0x09,0x3C,0xEE,0x45,0x49,0x6A,0xA6,0x10,0x3C};
//vider
const uint8_t spW135430 [] PROGMEM ={0xA3,0x0F,0x36,0xCC,0x2B,0x2B,0xAD,0xD5,0xBB,0xE4,0xE8,0xAA,0xB4,0x96,0x60,0xC3,0xD4,0x63,0xF1,0x59,0x92,0x72,0x57,0xD3,0xAC,0x6B,0xA9,0x5C,0xCD,0x54,0x95,0xAC,0xB6,0x2B,0x63,0x32,0x6F,0x73,0xEA,0x6E,0x54,0x28,0xA3,0xCD,0x29,0x07,0x25,0xCB,0xA9,0x96,0xA7,0x28,0x98,0xB3,0xAB,0x22,0x9E,0xA2,0x63,0xD6,0xA8,0x1E,0xBD,0x8A,0xC6,0x45,0xB8,0x66,0x74,0xAA,0x8D,0x90,0xA8,0x4E,0x33,0xB0,0xC6,0xA1,0x8D,0x55,0xAD,0xF2,0x9A,0x2A,0x67,0x89,0x8A,0x49,0x67,0x2A,0x5A,0xC4,0xA6,0x2E,0x9F,0xA5,0x0A,0xB6,0xAC,0x1A,0x75,0xD6,0x2A,0x44,0x63,0xFA,0xE4,0xD9,0x9A,0x56,0xD2,0xED,0x59,0xEB,0xA8,0x52,0xC4,0xA7,0x0B,0x8E,0xAB,0x32,0x96,0x9A,0x2A,0x55,0xAE,0x4A,0x44,0xF3,0xAA,0xD4,0x03};
//le
const uint8_t spW076448 [] PROGMEM ={0x30,0xC6,0xA0,0xC5,0x32,0xAF,0xF6,0x1A,0x83,0x61,0x8B,0xAE,0x25,0xA7,0xAF,0x54,0xD2,0xB3,0xDA,0x9C,0x3E,0x51,0x6B,0xAF,0xEC,0x78,0xFA,0x24,0x22,0x39,0xB2,0xD5,0x69,0xA2,0xF2,0xD4,0xB0,0x45,0xF0};
//bac
const uint8_t spW012156 [] PROGMEM ={0xA9,0x93,0x3C,0x33,0xCB,0x62,0xB9,0x09,0xFA,0x0A,0x4B,0x8F,0x74,0xEA,0x2C,0x2D,0x2C,0xBC,0xD6,0x19,0xAB,0xF2,0x74,0xAB,0x96,0x67,0xEB,0x4E,0x33,0xC2,0x17,0x9F,0xBD,0x3B,0x4F,0x0D,0x5F,0x74,0xF6,0xE1,0xC5,0xBD,0xA2,0xD2,0x39,0x9A,0x63,0xF1,0xCC,0x32,0xED,0x68,0x86,0xA9,0x2E,0x42,0xB1,0x23,0x11,0x66,0x4F,0x77,0x8C,0x8E,0x21,0x55,0x4C,0xD4,0x0E,0x3A,0xBA,0x10,0x11,0x55,0xCB,0x00,0x40,0x80,0x1B,0x45,0x15,0xB0,0x25,0x89,0x00,0x16,0x21,0x53,0xC0,0x51,0x24,0x0A,0x38,0x8A,0x58,0x00,0x5B,0x09,0x3F};
//marc
const uint8_t spW080198 [] PROGMEM ={0x6D,0xF2,0x24,0xFC,0xCA,0x23,0xB7,0x51,0x0B,0x9D,0xCE,0xB0,0x39,0x26,0x23,0x65,0xBB,0xDD,0xD2,0x9A,0x84,0xF1,0xAC,0x6C,0x3B,0x67,0xCD,0x36,0x1D,0x3D,0x2A,0x9F,0xBD,0x9A,0xA8,0x10,0x4B,0x78,0xF6,0xE2,0xAB,0x5C,0xCA,0xE6,0x39,0x72,0x3C,0x75,0xCB,0xD0,0xE7,0xCA,0x69,0xC3,0xAD,0x82,0x9C,0xBD,0xC4,0xC9,0x50,0xAF,0x70,0xF6,0xA1,0x2B,0xAF,0xA4,0x8B,0x03,0xAA,0x2E,0x33,0x40,0x11,0x29,0x06,0xE8,0xA6,0x59,0x01,0x35,0x88,0xC0,0x03};
int trigPin = 9 ;
int echoPin = 10 ;
int led = 7;
pinMode (led, OUTPUT);
pinMode (trigPin, OUTPUT);
pinMode (echoPin, INPUT);
//put your setup code here, to run once:
// set up the ADC
ADCSRA &= ~PS_128; // remove bits set by Arduino library
// you can choose a prescaler from above.
// PS_16, PS_32, PS_64 or PS_128
ADCSRA |= PS_32; // ## was 16 but give problem with getmode unstable 32 seems ok
//Réglage des paramêtres de restitution vocale
voice.SetSpeed(800); //entre 0 et 1023 . augmenter la valeur pour augmenter la vitesse. Valeur normal=800
voice.SetPitch(1023); //entre 0 et 1023 : Pitch normal=700. Augmenter pour rendre la voix plus aigue
//voice.SetBending(120);//entre 0 et 1023 : 0=pas de distortion ; 512=ion maximale ; 1023=pas de distortion
//voice.BendingOn();
voice.BendingOff(); //Pas de distortion du son
digitalWrite(led, LOW);
long duration, distance;
digitalWrite (trigPin,HIGH);
delayMicroseconds (1000);
digitalWrite (trigPin, LOW);
duration=pulseIn(echoPin, HIGH);
distance = (duration/2)/29.1;
Serial.print(distance);
Serial.println("CM");
delay(10);
if ((distance <=10))
digitalWrite(led, HIGH);
voice.say(spW135224);
voice.say(spW135430);
voice.say(spW076448);
voice.say(spW012156);
voice.say(spW080198);
voice.SetSpeed(800); voice.SetPitch(1023); voice.BendingOff();
else if(distance>10)
