Have -2.5V to 2.5V analog input, how to shift?
A summing amplifier would probably be more precise than the resistor method. But, if you are "smart", you should be able to "calibrate-out" any errors or small offsets in software...
A 2-input summing amplifier is an op-amp and 3 resistors. But a single-stage summing amplifier inverts the signal, so you need a 2nd op-amp (or a dual op-amp) and 2 more resistors for another inverter-stage. And the op-amp, will need plus and minus power supplies to handle the inverted & shifted/biased voltage, and to make sure that you can go all the way down to zero-volts.
It would be a good idea to adjust your resistor network (or the gain of the amplifier) to allow for a slightly larger voltage range than you need (maybe +/- 3V or so). I don't know about the Arduino ADC, but typically, if you try to use the full-range of an ADC, you can get anomilies near the limits (0V & 5V). For example, if you have a -10mV input-offset error, you won't read zero 'till you input +10mV. Or, if your 5V supply is actually 4.9V, you might not read accurately above 4.9V.
Also, what is the best way to protect the Arduino, in case I end up with an input outside of that -5V range? I'd like to bring my input as close to 0-5V as possible,
A regular diode wired "backwards" to +5V, so that any input voltage above 5V* will "turn-on" the diode, "shorting" the "extra" voltage to the 5V supply. Another diode wired "backwards" the other way to ground will "short" any negative voltage to ground. (You need some resistance in series, so that these "shorts" don't draw excess current from whatever's connected to the input.)
*It actually takes 0.5 to 0.7V to turn-on a silicon diode, so with the diodes you can get from -0.7V to +5.7V into the Arduino. But, that's safe.
