This is only my third project and I am not that familiar with coding.
I have searched and search but can't find an answer to this. I thought maybe a "for loop" but I can't figure out how I could make it work. My thought is that both variables that turn on the fans are stuck in the same loop and need to be separated. But I am not sure..
I have two 12VDC fans connected to two separate relays. They are to be controlled by seperate thermistors.
This is just rough, the temp isn't the issue I just set a range I want them to work in.
The problem is no matter which relay is is high, if I cool one thermistor off the other fan also shuts off. but the LED on the relay board indicating the fan that should still be on is still lit telling me it is still receiving a high signal.
if I pull either data line 10 or 11 from the relay board they both shut off but the one line I didn't pull off keeps the LED lit as it is receiving a high signal.
#include <LiquidCrystal.h> // load this library file
LiquidCrystal lcd(2, 3, 4, 5, 6, 7); // Sets the interface pins up in the library
int val=0; // starts val equal to zero
int val2=0; // starts val2 equal to zero
int val3=0; // starts val3 equal to zero
int val4=0; // starts val4 equal to zero
const int TempS=A5;
const int TempS2=A3;
const int Relay1 = 10;
const int Relay2 = 11;
const int low=492; // low end of temp
const int high=505; // high end of temp
const int low2=492; // low end of temp
const int high2=505; // high end of temp
byte degree[8] = {
B00110,
B01001,
B01001,
B00110,
B00000,
B00000,
B00000,
B00000,
pinMode (Relay1,OUTPUT); // set Relay1 as output
pinMode (Relay2,OUTPUT); // set Relay2 as output
lcd.begin(16, 2); // sets the LCD up with columns and rows
lcd.print("FAN 1 FAN 2"); // prints txt at default location 0,0
lcd.createChar(0,degree); // set degree special character to 0
lcd.setCursor(3,1); // move cursor to second line 3th position
lcd.write((byte)0); // display the degree special character
lcd.setCursor(4,1); // set cursor to the second line 4th position
lcd.print("C");
lcd.setCursor(13,1); // move cursor to second line 13th position
lcd.setCursor(14,1); // set cursor to the second line 14th position
lcd.print("C");
val = analogRead(TempS);
val3 = analogRead(TempS2);
if (val >= high)
digitalWrite(Relay1,LOW);
digitalWrite(Relay1,HIGH);
if (val3 >= high2)
digitalWrite(Relay2,LOW);
digitalWrite(Relay2,HIGH);
val2 = map(val, low, high, 20, 30);
val4 = map(val3, low2, high2, 20, 30);
lcd.setCursor(0,1); // move cursor to second line, 0 position
lcd.print(val2); // sends mapped equiv to LCD
delay(1000); // 1 second delay
lcd.setCursor(10,1); // move cursor to second line, 10th position
lcd.print(val4); // sends mapped equiv to LCD
