Have an object as a class attribute
I am trying to control a 2DOF SCARA arm that will interpret g codes. I split the code into 3 classes : ArmController, Kinematics and CmdProcessor. In my main file I make an instance of ArmController then an instance of CmdProcessor. CmdProcessor needs to be able to access ArmController to call armctl.moveTo(). I am used to c# so this may not be how it's done in c++. I have no idea on how to even start fixing this or which parts of the code may be important, so I just posted the entire code.
Main file:
//#include <AccelStepper.h>
#include "ArmController.h"
#include "CommandProcessor.h"
ArmCtl armctl(220, 205);
CmdProcessor cmd(armctl);
  armctl.Calibrate();
  armctl.Tick();
  cmd.ProcessSerial();
ArmController.h:
#define ArmController_h
#include <Arduino.h>
#include "Kinematics.h"
class ArmCtl{
  public:
    ArmCtl(float len1, float len2);
    void moveTo(float x, float y, float z);
    void Calibrate();
    void Reset();
    void Joystick();
    void Tick();
    void CheckSteppers();
    Kinematics kinematics;
    AccelStepper s1;
    AccelStepper s2;
    AccelStepper s3;
    float l1;
    float l2;
    float x;   //
    float y;   // X Y and Z coordinates of end effector
    float z;   //
    float x1();  //
    float y1();  //X and Y coordinates of elbow
    float a;   //
    float b;   //Raw stepper angles
    float c;   //
ArmCtl::ArmCtl(float len1, float len2) : kinematics(len1, len2){
  s1 = AccelStepper(8, 2, 4, 3, 5);
  s2 = AccelStepper(8, 6, 8, 7, 9);
  s3 = AccelStepper(8, 10, 12, 11, 13);
  s1.setMaxSpeed(500);
  s1.setAcceleration(4000);
  s2.setMaxSpeed(1500);
  s2.setAcceleration(4000);
  s2.setCurrentPosition(46194);
  s3.setMaxSpeed(2000);
  s3.setAcceleration(4000);
  l1 = len1;
  l2 = len2;
void ArmCtl::Tick(){
  if(analogRead(2) < 2){
    Calibrate();
  Joystick();
  s1.run();
  s2.run();
  s3.run();
void ArmCtl::CheckSteppers(){
  if(abs(s1.distanceToGo()) == 0)
    s1.disableOutputs();
  if(abs(s2.distanceToGo()) == 0)
    s2.disableOutputs();
  if(abs(s3.distanceToGo()) == 0)
    s3.disableOutputs();
void ArmCtl::moveTo(float x_, float y_, float z_){
  x = x_;
  y = y_;
  z = z_;
  a = kinematics.calcAngle1(x,y);
  b = kinematics.calcAngle2(x,y);
  s1.moveTo((92389 / 360) *a);
  s2.moveTo((92389 / 360) *b);
  Serial.println(String(x) + " " + String(y) + " " + String(z));
void ArmCtl::Calibrate(){
  Reset();
  while(analogRead(2) > 2){
    CheckSteppers();
    int xr = analogRead(0);
    if(xr > 768){
      s1.setSpeed((xr - 768)*4);
      s1.runSpeed();
    else if( xr < 256){
      s1.setSpeed((xr - 256)*4);
      s1.runSpeed();
    int yr = analogRead(1);
    if(yr > 768){
      s2.setSpeed((yr - 768)*4);
      s2.runSpeed();
    else if( yr < 256){
      s2.setSpeed((yr - 256)*4);
      s2.runSpeed();
    if(analogRead(3)<256){
      s3.setSpeed(1024);
      s3.runSpeed();
    else if(analogRead(4)<256){
      s3.setSpeed(-1024);
      s3.runSpeed();
  s1.setCurrentPosition(0);
  s1.setSpeed(500);
  s2.setSpeed(500);
void ArmCtl::Reset(){
  s1.moveTo(0);
  s2.moveTo(46194);
  s3.moveTo(0);
  while(!(s1.distanceToGo() == 0 && s2.distanceToGo() == 0 && s3.distanceToGo() == 0)){
    s1.run();
    s2.run();
    s3.run();
  CheckSteppers();
void ArmCtl::Joystick(){
  if(abs(s1.distanceToGo()) < 5000 && abs(s2.distanceToGo()) < 5000 && abs(s3.distanceToGo()) < 5000){
    if(analogRead(0)>768){
      x+=(analogRead(0) - 768)/32;
      moveTo(x,y,z);
    else if(analogRead(0)<256){
      x-=(256 - analogRead(0))/32;
      moveTo(x,y,z);
    if(analogRead(1)>768){
      y+=(analogRead(1) - 768)/32;
      moveTo(x,y,z);
    else if(analogRead(1)<256){
      y+=(256 - analogRead(0))/32;
      moveTo(x,y,z);
      z+=5;
      moveTo(x,y,z);
      z-=5;
      moveTo(x,y,z);
CmdProcessor.h:
#define CommandProcessor_h
class CmdProcessor{
  public:
    CmdProcessor(ArmCtl armc);
    void ProcessSerial();
    ArmCtl ctl;
  private:
    String cmd;
    void G0(); //go to pos
    void G1(); //home
    void G2(float a1,float a2, float a3); //Set raw stepper angles
CmdProcessor::CmdProcessor(ArmCtl& armc){
  ctl = armc;
void CmdProcessor::ProcessSerial(){
  if(Serial.available()){
    cmd += (char)Serial.read();
    if(cmd == "G0"){
      cmd = "";
      Serial.println("ok G0");
      G0();
    else if(cmd == "G1"){
      cmd = "";
      Serial.println("ok G1");
      G1();
    if(cmd.length() == 2){
      Serial.println("command unrecognized: " + cmd);
      cmd = "";
void CmdProcessor::G0(){
  float x = Serial.parseFloat();
  float y = Serial.parseFloat();
  ctl.moveTo(x,y,0);
void CmdProcessor::G1(){
  ctl.Reset();
Kinematics.h:
#define Kinematics_h
class Kinematics{
  public:
    Kinematics(float l1, float l2){
      length1 = l1;
      length2 = l2;
    float calcAngle1(float x,float y){
      float distance = sqrt(x*x + y*y);
      float D1 = RadToDeg(atan2(y, x));
      float D2 = RadToDeg(LawOfCosines(distance, length1, length2));
      if(x<0){
        return -(180 - abs(90 - (D1 + D2)));
      return 90 - (D1 + D2);
    float calcAngle2(float x,float y) {
      if(x<0){
        return 180 + RadToDeg(LawOfCosines(length1, length2, distance));
      return 180 - RadToDeg(LawOfCosines(length1, length2, distance)); //Subtract from 180 because this stepper is upside down so the angles have to be reversed
  private:
    float length1;
    float length2;
    float RadToDeg(double rad) {
      return float (rad * 180 / 3.1416);
    float LawOfCosines(float a, float b, float c){
      return acos((a*a + b*b - c*c) / (2 * a * b));
When I try to compile all this I get this:
In file included from sketch\CommandProcessor.h:2:0,
                 from C:\Users\Alp D\Desktop\Coding\Armatron_S\Armatron_S\Armatron_S.ino:3:
sketch\ArmController.h: In constructor 'ArmCtl::ArmCtl()':
ArmController.h:44: error: no matching function for call to 'Kinematics::Kinematics()'
 ArmCtl::ArmCtl(){
sketch\ArmController.h:44:16: note: candidates are:
In file included from sketch\ArmController.h:3:0,
                 from sketch\CommandProcessor.h:2,
sketch\Kinematics.h:5:5: note: Kinematics::Kinematics(float, float)
sketch\Kinematics.h:5:5: note:   candidate expects 2 arguments, 0 provided
sketch\Kinematics.h:3:7: note: constexpr Kinematics::Kinematics(const Kinematics&)
 class Kinematics{
sketch\Kinematics.h:3:7: note:   candidate expects 1 argument, 0 provided
sketch\Kinematics.h:3:7: note: constexpr Kinematics::Kinematics(Kinematics&&)
C:\Users\Alp D\Desktop\Coding\Armatron_S\Armatron_S\Armatron_S.ino: In function 'void loop()':
Armatron_S:11: error: 'cmd' was not declared in this scope
exit status 1
Also English isn't my primary language so I may make some mistakes.
The compiler is reminding you that your Kinematics constructor takes two parameters:
But you tried to declare it with none:
How can I declare it? Is that initializing it? Isn't it declared in the constructor?
  l1 = len1;
  l2 = len2;
Don't put function implementations of the form "ArmCtl::ArmCtl" in the .h file. They must go in a .cpp file of the same name. Be sure to #include the .h file in the .cpp file. See my Reply #3 Here.
Let's see if I can get this right :grin:
In your class you have "defined" that the constructor takes 2 floats as parameters.
But when you "declared" an object of that class you did not include the required float variables.
Kinematics kinematics(float1, float2);
I split the ArmController into ArmController.h and ArmController.cpp and now I get this:
Arduino: 1.6.9 (Windows 10), Board: "Arduino/Genuino Uno"
In file included from sketch\ArmController.cpp:1:0:
ArmController.h:11: error: 'Kinematics' does not name a type
ArmController.h:12: error: 'AccelStepper' does not name a type
     AccelStepper s1;
ArmController.h:13: error: 'AccelStepper' does not name a type
     AccelStepper s2;
ArmController.h:14: error: 'AccelStepper' does not name a type
     AccelStepper s3;
sketch\ArmController.cpp: In constructor 'ArmCtl::ArmCtl(float, float)':
ArmController.cpp:4: error: class 'ArmCtl' does not have any field named 'kinematics'
ArmController.cpp:5: error: 's1' was not declared in this scope
ArmController.cpp:6: error: 's2' was not declared in this scope
ArmController.cpp:7: error: 's3' was not declared in this scope
sketch\ArmController.cpp: In member function 'void ArmCtl::Tick()':
ArmController.cpp:24: error: 's1' was not declared in this scope
   s1.run();
ArmController.cpp:25: error: 's2' was not declared in this scope
   s2.run();
ArmController.cpp:26: error: 's3' was not declared in this scope
   s3.run();
In file included from sketch\ArmController.cpp:2:0:
sketch\ArmController.cpp: In member function 'void ArmCtl::CheckSteppers()':
ArmController.cpp:29: error: 's1' was not declared in this scope
C:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino/Arduino.h:86:18: note: in definition of macro 'abs'
 #define abs(x) ((x)>0?(x):-(x))
ArmController.cpp:31: error: 's2' was not declared in this scope
ArmController.cpp:33: error: 's3' was not declared in this scope
sketch\ArmController.cpp: In member function 'void ArmCtl::moveTo(float, float, float)':
ArmController.cpp:40: error: 'kinematics' was not declared in this scope
ArmController.cpp:42: error: 's1' was not declared in this scope
ArmController.cpp:43: error: 's2' was not declared in this scope
sketch\ArmController.cpp: In member function 'void ArmCtl::Calibrate()':
ArmController.cpp:52: error: 's1' was not declared in this scope
ArmController.cpp:56: error: 's1' was not declared in this scope
ArmController.cpp:61: error: 's2' was not declared in this scope
ArmController.cpp:65: error: 's2' was not declared in this scope
ArmController.cpp:69: error: 's3' was not declared in this scope
       s3.setSpeed(1024);
ArmController.cpp:73: error: 's3' was not declared in this scope
       s3.setSpeed(-1024);
ArmController.cpp:78: error: 's1' was not declared in this scope
ArmController.cpp:79: error: 's2' was not declared in this scope
sketch\ArmController.cpp: In member function 'void ArmCtl::Reset()':
ArmController.cpp:84: error: 's1' was not declared in this scope
   s1.moveTo(0);
ArmController.cpp:85: error: 's2' was not declared in this scope
   s2.moveTo(46194);
ArmController.cpp:86: error: 's3' was not declared in this scope
   s3.moveTo(0);
sketch\ArmController.cpp: In member function 'void ArmCtl::Joystick()':
ArmController.cpp:95: error: 's1' was not declared in this scope
ArmController.cpp:95: error: 's2' was not declared in this scope
ArmController.cpp:95: error: 's3' was not declared in this scope
exit status 1
option enabled in File -> Preferences.
ArmController.cpp:
  l1 = len1;
  l2 = len2;
    Calibrate();
  Joystick();
  s1.run();
  s2.run();
  s3.run();
  x = x_;
  y = y_;
  z = z_;
  Reset();
    CheckSteppers();
    if(xr > 768){
      s1.runSpeed();
    else if( xr < 256){
      s1.runSpeed();
    if(yr > 768){
      s2.runSpeed();
    else if( yr < 256){
      s2.runSpeed();
      s3.setSpeed(1024);
      s3.runSpeed();
      s3.setSpeed(-1024);
      s3.runSpeed();
  s1.setSpeed(500);
  s2.setSpeed(500);
  s1.moveTo(0);
  s2.moveTo(46194);
  s3.moveTo(0);
    s1.run();
    s2.run();
    s3.run();
  CheckSteppers();
      moveTo(x,y,z);
      moveTo(x,y,z);
      moveTo(x,y,z);
      moveTo(x,y,z);
      z+=5;
      moveTo(x,y,z);
      z-=5;
      moveTo(x,y,z);
How can I declare it in a class without doing that? I get this when I try to declare it with the required floats:
*some more error messages*
ArmController.h:12: error: 'l1' has not been declared
     Kinematics kinematics(l1, l2);
ArmController.h:12: error: 'l2' has not been declared
*some more error messages*                               ^
class ArmCtl{
  public:
    void Calibrate();
    void Reset();
    void Joystick();
    void Tick();
    AccelStepper s1;
    AccelStepper s2;
    AccelStepper s3;
    float l1;
    float l2;
    float x;   //
    float z;   //
    float x1();  //
    float a;   //
    float c;   //
