Have exhausted everything I can think of...
I am helping a student and would appreciate new eyes on this. I cannot figure out what I’m missing.
I have a simple strip of 3 neopixels that I am trying to cycle through colors. I found and tested the blue function but when I replicated it for the other colors (red, green, yellow), the strip only shows blue. Thank you.
///code from https://www.arduinoplatform.com/arduino-visual-output/controlling-and-powering-neopixels-with-arduino/
///http://www.highschoolmaker.com/electronics-with-micro-controllers/chapter-8-neopixels/8-2-create-some-neopixel-functions/
#define PIN 10
#define LEDS 3
Adafruit_NeoPixel strip = Adafruit_NeoPixel(LEDS, PIN, NEO_GRB + NEO_KHZ800);
  strip.begin();
  strip.show();  // Initialize all pixels to 'off'
   blue();
   red();
   green();
   yellow();
void red()
  for(int i = 0; i < LEDS; i++){
    strip.setPixelColor(i, (255,0,0));
  strip.show();
void blue()
    strip.setPixelColor(i, (0,0,255));
  strip.show();
void green()
    strip.setPixelColor(i, (0,255,0));
  strip.show();
void yellow()
    strip.setPixelColor(i,(255,215,0));
  strip.show();
You’ve written the colors wrong. Lose the parentheses.
setPixelColor(i, 215, 230, 200);
HTH
a7
Presuming you are using the Arduino IDE, set File>Preferences>Compiler warnings to "All" and you will see a few instances of the following:
/home/jdbarney/Arduino/forumtest/forumtest.ino: In function 'void red()':
/home/jdbarney/Arduino/forumtest/forumtest.ino:34:34: warning: left operand of comma operator has no effect [-Wunused-value]
     strip.setPixelColor(i, (255, 0, 0));
/home/jdbarney/Arduino/forumtest/forumtest.ino:34:37: warning: right operand of comma operator has no effect [-Wunused-value]
You've written the colors wrong. Lose the parentheses.
You can also use .Color() to convert the RGB values into a single uint32_t, handy if you want to store the colors in a variable or array.
    strip.setPixelColor(i, strip.Color(255, 0, 0));
