Have I achieved a null- terminated C-string through the code?
#include <Wire.h>
#include <hd44780.h>                       // main hd44780 header
#include <hd44780ioClass/hd44780_I2Cexp.h> // i2c expander i/o class header
hd44780_I2Cexp lcd; // declare lcd object: auto locate & config exapander chip
// LCD geometry
const int LCD_COLS = 16;
const int LCD_ROWS = 2;
#include <Keypad.h>
const byte ROWS = 4; //four rows
const byte COLS = 4; //three columns
char keys[ROWS][COLS] = {
  {'1', '2', '3', 'A'},
  {'4', '5', '6', 'B'},
  {'7', '8', '9', 'C'},
  {'*', '0', '#', 'D'}
byte rowPins[ROWS] = {6, 7, 8, 9}; //connect to the row pinouts of the keypad
byte colPins[COLS] = {5, 4, 12, 11}; //connect to the column pinouts of the keypad
Keypad keypad = Keypad( makeKeymap(keys), rowPins, colPins, ROWS, COLS );
bool a = true;
  lcd.begin(LCD_COLS, LCD_ROWS);
  lcd.setCursor(3, 0);
  lcd.print("  PRIYA");
  lcd.setCursor(3, 1);
  lcd.print("ELECTRONICS");
  delay(100);
  for (int positionCounter = 0; positionCounter < 40; positionCounter++)
    lcd.scrollDisplayLeft();
    delay(120);
  delay(800);
  lcd.clear();
  lcd.setCursor(0, 0);
  lcd.print("Set Count:");
//unsigned long total;
  const byte entryMaxSize = 5;
  static char count[entryMaxSize];
  static byte x; // index
  char key = keypad.getKey();
  if (key != NO_KEY) // Check for a valid key.
    switch (key)
      case 'A':
        lcd.clear();
        x = 0; // reset the counter
        a = true;
        count[5] = '\0';
      case 'D':
        if (a) {
          if (x == 0)
            invalidCount();
          else {
            lcd.clear();
            lcd.print("Count Set:");
            for (byte i = 0; i < x; i++) {
              lcd.print(count[i]);
              a = false;
      default:
        if (a)
          // if not 5 characters yet
          if (x < entryMaxSize)
            // add key to userinput array and increment counter
            if ( key >= '0' && key <= '9' ) // key is of type char and has a value between 0 and 9 so do something with it.
              count[x++] = key;
              lcd.print( key ) ;  // new print statement <<<<<<<<<<<<<<<<
              //total = ((count[ 0 ] - '0') * 10000UL  + (count[ 1 ] - '0') * 1000 + (count[ 2 ] - '0') * 100 + (count[3] - '0') * 10 + (count[4] - '0'));
          else {
            countWarning();
void invalidCount()
  lcd.clear();
  lcd.print("Invalid Count!!");
  lcd.setCursor(0, 1);
  lcd.print("Press A"); // suggesting the user to enter the count again
  a = false;
void countWarning()
  lcd.clear();
  lcd.print("5 Digits Only!!"); // warning for the user if more than permitted digits are entered
  a = false;
If corrections are required please suggest them. Thanks.
Gautam
        count[5] = '\0';
count[5] is no man's land.
You need to keep track of where you are writing into the count array. Each time you write a new value into the array, put a NULL in the next position.
If you want to store 5 digits in count, count needs to have 6 elements, not 5.
Could anybody make the necessary changes to the code please?
  const byte entryMaxSize = 6;
PaulS:
I guess I am already tracking where I am writing the count, only the Null is missing..
And how do I use the null terminator with my current code?
If the string is always going to be 5 chars long then do as I suggested and write the '\0' to count[5] as you do now.
If not then write the '\0' to the next array position as you go along. I would suggest doing it that way anyway.
UKHeliBob:
Okay. How should the code look like then, if a null terminator is to be written as I go along the array?
Write a character into an element of the array, and write \0 into the next element.
Could anyone help me with a piece of code to implement it?
array [index++] = charRead;
array [index] = '\0';
AWOL:
which place in my code should I use this?
GautamD:
Where you add each character to the array
Now its allowing me to enter 6 digits instead of 5.
#include <Wire.h>
// LCD geometry
#include <Keypad.h>
bool a = true;
  delay(100);
    delay(120);
  delay(800);
  lcd.clear();
    switch (key)
      case 'A':
        lcd.clear();
        a = true;
      case 'D':
        if (a) {
          if (x == 0)
            invalidCount();
          else {
            lcd.clear();
              a = false;
      default:
        if (a)
              count[x++] = key;
              count[x] = '\0';
          else {
            countWarning();
void invalidCount()
  lcd.clear();
  a = false;
void countWarning()
  lcd.clear();
  a = false;
Change
to
          if (x < entryMaxSize - 1)
Did you write this code or copy it from somewhere, not that it would be a bad thing, but you should make some effort to understand how it works if you did.
UKHeliBob:
Part of it I've written it myself and for some part I got help from the guys on the forum.
Latest:
#include <Wire.h>
// LCD geometry
#include <Keypad.h>
bool a = true;
  delay(100);
    delay(120);
  delay(800);
  lcd.clear();
    switch (key)
      case 'A':
        lcd.clear();
        a = true;
      case 'D':
        if (a) {
          if (x == 0)
            invalidCount();
          else {
            lcd.clear();
              a = false;
      default:
        if (a)
              count[x++] = key;
              count[x] = '\0';
          else {
            countWarning();
void invalidCount()
  lcd.clear();
  a = false;
void countWarning()
  lcd.clear();
  a = false;
Now you might consider the declaration of your variables. It will work as it is but could be confusing at a later date.
Perhaps
  static char count[entryMaxSize + 1];
Then remove the -1 from the test for max entry size later in the code
Latest :
#include <Wire.h>
// LCD geometry
#include <Keypad.h>
bool a = true;
  delay(100);
    delay(120);
  delay(800);
  lcd.clear();
    switch (key)
      case 'A':
        lcd.clear();
        a = true;
      case 'D':
        if (a) {
          if (x == 0)
            invalidCount();
          else {
            lcd.clear();
              a = false;
      default:
        if (a)
              count[x++] = key;
              count[x] = '\0';
          else {
            countWarning();
void invalidCount()
  lcd.clear();
  a = false;
void countWarning()
  lcd.clear();
  a = false;
Am I ready to convert count to an unsigned long value?
You tell us. Do you have all 5 values? Do you need to have 5 values to do the conversion?
