Hey guys, im here again, i have a problem with multiserial and LCD16x2, maybe is that im not used to Arduino mega and it multiserial ports or functions. When i use the normal serial (serial.begin), my lcd show me the value of the MG811 sensor, but when i use the Serial2.begin and the condition of that serial, my LCD don't show me anything. Don't know what is the problem, here is my code:
#include "CO2Sensor.h"
#include <Wire.h>
LiquidCrystal_I2C lcd(0x27,20,4); // set the LCD address to 0x27 for a 16 chars and 2 line display
CO2Sensor co2Sensor(A0, 0.99, 100);
String val_CO2;
lcd.init();
lcd.backlight();
lcd.setCursor(0, 0);
lcd.print("Temp: ");
lcd.setCursor(0, 1);
lcd.print("CO2:");
//lcd.setCursor(7, 1);
//lcd.print("CO:");
Serial2.begin(9600);
co2Sensor.calibrate();
if (Serial2.available()){
int val = co2Sensor.read();
lcd.setCursor(4, 1);
lcd.print(val);
//CO2 sensor
If you change the Serial2.begin to serial.begin, and erase the condition of Serial2.available, it works fine. Hope somebody can help me
The Mega has 4 UARTs (serial ports). The UART (Serial) is connected to
Pins 0 and 1
A serial-to-usb converter for communication with the PC
The other UARTs are connected to other pins and are not connected to a / the serial-to-usb converter. So there is no way that Serial1, Serial2 and Serial3 can communicate with a PC unless you add external serial-to-usb adapters and connect those to a / the PC.
Ty, i wasn't sure about that fact, then i need to change some parts of my code to use the serial 2, I hope i can send the data of Rx 2 to the LCD. At first i use serial 0 to communicate my FPGA Artix 7, now i will change to UART 2
