Have some trouble for the code.
This is the website for my lab, and I used this code but it doesn't work. So, Can I know where is wrong for the code?
Ancheng:
You need to post the code here.
Please use code tags (</> button on the toolbar) when you post code or warning/error messages. The reason is that the forum software can interpret parts of your code as markup, leading to confusion, wasted time, and a reduced chance for you to get help with your problem. This will also make it easier to read your code and to copy it to the IDE or editor. If your browser doesn’t show the posting toolbar then you can just manually add the code tags:
[code]``[color=blue]// your code is here[/color]``[/code]
Using code tags and other important information is explained in the How to use this forum post. Please read it.
Please always do a Tools > Auto Format on your code before posting it. This will make it easier for you to spot bugs and make it easier for us to read. If you’re using the Arduino Web Editor you will not have access to this useful tool but it’s still unacceptable to post poorly formatted code. I recommend you to use the standard IDE instead.
Please remove unnecessary blank lines from your code before posting to the forum. One or two to separate code into logical sections is fine but large spaces for no reason or random blank lines just make for more scrolling when we’re trying to read your code.
When your code requires a library that’s not included with the Arduino IDE please always post a link (using the chain link icon on the toolbar to make it clickable) to where you downloaded that library from or if you installed it using Library Manger(Sketch > Include Library > Manage Libraries) then say so and state the full name of the library.
When you post a link please use the chain link icon on the toolbar to make it clickable.
Ancheng:
it doesn’t work.
Explain exactly what you mean by “it doesn’t work”. Provide all the details we would need to reproduce the problem you’re having.
