Having a delay created after button is pressed to avoid activations in quick succession
Im creating a counter and dont want it to be able to be activated in quick succession, but cant figure out where to put the delay. its only needed after the button (bt_up) is pressed, i want the code to activate immediately but then not be able to be triggered again for 10 seconds
#include <EEPROM.h>
#define bt_up     A0
#define bt_down   A1
#define bt_reset  A2
#define buzzer 13
#define MAX7219_Clock 2
#define MAX7219_Chip_Select  3
#define MAX7219_Data_IN 4
long d1=0, d2=0, d3=0, d4=0, d5=0, d6=0, d7=0, d8=0;
int flag1=0, flag2=0, timer=0;
void setup() { // put your setup code here, to run once
pinMode(bt_up,    INPUT_PULLUP);
pinMode(bt_down,  INPUT_PULLUP);
pinMode(bt_reset, INPUT_PULLUP);
pinMode(buzzer, OUTPUT);
pinMode(MAX7219_Data_IN, OUTPUT);
pinMode(MAX7219_Chip_Select, OUTPUT);
pinMode(MAX7219_Clock, OUTPUT);
digitalWrite(MAX7219_Clock, HIGH);
delay(200);
//Setup of MAX7219 chip
shift(0x0f, 0x00); //display test register - test mode off
shift(0x0c, 0x01); //shutdown register - normal operation
shift(0x0b, 0x07); //scan limit register - display digits 0 thru 7
shift(0x0a, 0x0f); //intensity register - max brightness
shift(0x09, 0xff); //decode mode register - CodeB decode all digits
if(EEPROM.read(0)==0){
}else{WriteEeprom(); EEPROM.write(0,0);}
ReadEeprom();
if(digitalRead (bt_up) == 0){
  digitalWrite(buzzer, HIGH);
if(flag1==0){ flag1=1;
d1=d1+1;
if(d1>9){d1=0; d2=d2+1;}
if(d2>9){d2=0; d3=d3+1;}
if(d3>9){d3=0; d4=d4+1;}
if(d4>9){d4=0; d5=d5+1;}
if(d5>9){d5=0; d6=d6+1;}
if(d6>9){d6=0; d7=d7+1;}
if(d7>9){d7=0; d8=d8+1;}
if(d8>9){d8=0;}
WriteEeprom();
}else{flag1=0;}
if(digitalRead (bt_down) == 0){
if(flag2==0){ flag2=1;
d1=d1-1;
if(d1<0){d1=9; d2=d2-1;}
if(d2<0){d2=9; d3=d3-1;}
if(d3<0){d3=9; d4=d4-1;}
if(d4<0){d4=9; d5=d5-1;}
if(d5<0){d5=9; d6=d6-1;}
if(d6<0){d6=9; d7=d7-1;}
if(d7<0){d7=9; d8=d8-1;}
if(d8<0){d8=9;}
WriteEeprom();
}else{flag2=0;}
if(digitalRead (bt_reset) == 0){
if(timer<200){timer=timer+1;}
if(timer==200){
WriteEeprom();
}else{digitalWrite(buzzer, LOW); timer=0;}
shift(0x01, d1);  //digit 0 (rightmost digit) data
shift(0x02, d2);
shift(0x03, d3);
shift(0x04, d4);
shift(0x05, d5);
shift(0x06, d6);
shift(0x07, d7);
shift(0x08, d8); //digit 7 (leftmost digit) data
delay(10);
void ReadEeprom() {
d1=EEPROM.read(1);
d2=EEPROM.read(2);
d3=EEPROM.read(3);
d4=EEPROM.read(4);
d5=EEPROM.read(5);
d6=EEPROM.read(6);
d7=EEPROM.read(7);
d8=EEPROM.read(8);
void WriteEeprom() {
EEPROM.write(1, d1);
EEPROM.write(2, d2);
EEPROM.write(3, d3);
EEPROM.write(4, d4);
EEPROM.write(5, d5);
EEPROM.write(6, d6);
EEPROM.write(7, d7);
EEPROM.write(8, d8);
void shift(byte send_to_address, byte send_this_data){
  digitalWrite(MAX7219_Chip_Select, LOW);
  shiftOut(MAX7219_Data_IN, MAX7219_Clock, MSBFIRST, send_to_address);
  shiftOut(MAX7219_Data_IN, MAX7219_Clock, MSBFIRST, send_this_data);
  digitalWrite(MAX7219_Chip_Select, HIGH);
Im using 8 digit 7 segment displays to count
Thanks for using code tags. 10 seconds after what event?
What is the purpose of this code? It appears to display 8 digits of data and store them into EEPROM.
Why do you want to wait 10 seconds between pushes? I think you would be better off using StateChangeDetection on the buttons and using millis() to constrain the time between pushes.
After the button is pressed which is indicated by bt_up after that is pressed the counter goes up by one
it counts up, so each time bt up is activated a 8 digit 7 segment display goes up by one
Do you want to lock out only that button for 10 seconds, or all buttons?
just that single button
Keep track of the last time the button was pressed by saving the value of millis when the button is pressed. Then, do not allow the button to register a press unless the current value of millis() minus what you saved, is greater than 10000.
