Having a problem w/comparison of strings received from serial port`
I’m having problems working with strings received from a serial port. I am able to buffer and receive the data and print it via:
Serial2.println(data3);
and all looks good but when I try to do a comparison of the string I don’t get a match. The serial processing and data comparison functions look like:
void monitorCNC()
    Serial2.print("Serial2 Bytes Available: ");
    Serial2.println(Serial3.available());
    static char input_line [MAX_INPUT];
    static unsigned int input_pos = 0;
    while (Serial3.available () > 0)
    char inByte3 = Serial3.read();
      switch (inByte3)
        case '\n':   // end of text
        input_line [input_pos] = 0;  // terminating null byte
        // terminator reached! process input_line here ...
        process_data (input_line);
        // reset buffer for next time
        input_pos = 0;
      case '\r':   // discard carriage return
      default:
        // keep adding if not full ... allow for terminating null byte
        if (input_pos < (MAX_INPUT - 1))
          input_line [input_pos++] = inByte3;
      }  // end of switch
// here to process incoming serial data after a terminator received
void process_data(char * data3)
  Serial2.print("Data3 Value: "); // debug info
  Serial2.println(data3); // debug info, this prints the expected string of "Grbl 0.9a ['
Serial2 is my debug monitor and I am reading the data from Serial3, Serial0 is also in use, but inconsequential to this step.
I think my problem is that Serial.println is noticing the type of data that is presented and processing it properly for printing, but that I am missing a step in the if comparison to properly match the entire string. Any ideas would be appreciated. I’ve done a lot of searching on “Arduino Serial Read String Comparison” and many similarly worded searches have turned up nothing useful, for me. for help]"
  if(data3 == "Grbl 0.9a [’
I think my problem is that Serial.println is noticing the type of data that is presented and processing it properly for printing, but that I am missing a step in the if comparison to properly match the entire string. Any ideas would be appreciated. I've done a lot of searching on "Arduino Serial Read String Comparison" and many similarly worded searches have turned up nothing useful, for me. for help]") // GRBL Init String, this comparison never works
    Serial2.println("CNC: Startup string received");
    Serial2.println("No Match");
You can not use == to compair strings, you need the C compair string function.
Excellent, thank you :)
Replaced
if(data3 == "Grbl 0.9a ['
With
if(strcmp(data3,"Grbl 0.9a ['
Working fine now. for help]") // GRBL Init String, this comparison never works ```
With
§_DISCOURSE_HOISTED_CODE_1_§
Working fine now. for help]") == 0) // GRBL Init String ```
With
Working fine now.
