Hello Everyone !!
While I am new to learning Arduino, this code below is a part of my work. My work is to try to execute the code and while trying I am receiving the error -" the function definition is not allowed here before '{' token". I don't know whether this kind of error has been dealt with before. Kindly provide me any help and also if possible some suggestions on the best way to learn Arduino FYI: I am new to Arduino. I am looking forward to hearing from you all. The code is below:
Thank you
#include <Wire.h>
#include <DallasTemperature.h>
#define RELAY1 4 // Relay heating
#define RELAY2 6 // Relay cooling
int red = 8; // red LED heating
int blue = 2; // blue LED cooling
#define BACKLIGHT_PIN 13
#define ONE_WIRE_BUS 7
LiquidCrystal_I2C lcd(0x3F, 2, 1, 0, 4, 5, 6, 7, 3, POSITIVE);
OneWire oneWire(ONE_WIRE_BUS);
DallasTemperature sensors(&oneWire);
{ %%%%% here the error is coming
sensors.begin();
lcd.begin(20,4);
lcd.backlight();
pinMode(red, OUTPUT);
pinMode(blue, OUTPUT);
pinMode(RELAY1, OUTPUT);
pinMode(RELAY2, OUTPUT);
lcd.setCursor(0, 0);
lcd.print(" TEMP CONTROL");
sensors.requestTemperatures();
float temperature = sensors.getTempCByIndex(0);
lcd.setCursor(0, 2);
lcd.print(" ");
lcd.print(sensors.getTempCByIndex(0));
lcd.print("\337C");
if(temperature < 25);
digitalWrite(red,HIGH);
digitalWrite(blue,LOW);
lcd.setCursor(0, 3);
lcd.print(" Heating");
digitalWrite(RELAY1,0);
digitalWrite(RELAY2,1);
else if(temperature > 25);
digitalWrite(RELAY1,1);
digitalWrite(RELAY2,0);
digitalWrite(red,LOW);
digitalWrite(blue,HIGH);
lcd.setCursor(0, 4);
lcd.print(" Cooling ");
a function-definition is not allowed here before '{' token"
