I'm developing a printing system for my final year project, using a Mega2560 and RAMPS 1.4 shield to control some stepper motors and an inkjet printhead.
I have successfully got the stepper motors to move in the desired fashion - they rotate a belt which is attached to a platform, causing the platform to move - using the code below. The basic idea is that the platform moves in parallel lines, with a small perpendicular movement at the end of the line. When a certain number of lines have been printed, the motors all stop. Eventually this will be positioned beneath a stream of ink droplets so that the ink prints a square shape.
#include <AccelStepper.h>
#define X_STEP_PIN 54
#define X_DIR_PIN 55
#define X_ENABLE_PIN 38
#define Y_STEP_PIN 60
#define Y_DIR_PIN 61
#define Y_ENABLE_PIN 56
#define Y_MIN_PIN 14
#define Y_MAX_PIN 15
AccelStepper Xaxis(1, X_STEP_PIN, X_DIR_PIN);
AccelStepper Yaxis(1, Y_STEP_PIN, Y_DIR_PIN);
Xaxis.setMaxSpeed(1000);
Xaxis.setAcceleration(10000);
Xaxis.moveTo(660);
Xaxis.setEnablePin(X_ENABLE_PIN);
Xaxis.setPinsInverted(false,false,true);
Xaxis.enableOutputs();
Yaxis.setMaxSpeed(10000);
Yaxis.setAcceleration(10000);
Yaxis.setEnablePin(Y_ENABLE_PIN);
Yaxis.setPinsInverted(false,false,true);
Yaxis.enableOutputs();
while (Yaxis.currentPosition() == 660)
Yaxis.stop();
Xaxis.stop();
if (Xaxis.distanceToGo() == 0)
Yaxis.move(66);
Xaxis.moveTo(-Xaxis.currentPosition());
Xaxis.run();
Yaxis.run();
My next challenge is to send a signal from another pin to cause actuation of the printhead. This has to be synchronised with the movement of the stepper motors - so that it starts printing when the platform starts moving, and stops printing when the platform stops moving. Otherwise there will just be a big mess of ink on one spot!
I've used the tone() function to send a square wave from a pin, which will be able to actuate the printhead. As I'm not connected to the printhead just yet, I have an LED and resistor connected to the pin to check if it's working.
I tried to add another bit into the loop so that noTone() is called once the stepper motors have reached the desired position - this is the same strategy I have used to get the stepper motors to stop. However the signal keeps on firing.
Yaxis.stop();
Xaxis.stop();
noTone(Trigger_PIN);
Yaxis.move(1);
Xaxis.run();
Yaxis.run();
tone(Trigger_PIN, 31);
Can anyone suggest how I can get noTone to stop the signal from firing once the stage reaches the desired position (660 steps) and stops?
That seems like an awful lot of explanation for such a simple problem - you can probably tell I've never done any coding before let alone used an Arduino!
Thanks in advance,
Michael
