Having Error in transmission of Serial commands to A6 GSM module
Serial communication happens only one time But next time the If loop executes then serial commands did not execute.
Code worked for 3 months but it stopped working on my machine suddenly please guide
char phone_no1[]="9860422730";
delay(400);
pinMode(13, OUTPUT);
if(digitalRead(8) == HIGH)
Serial.print("AT+CMGF=1\r\n");
delay(3000);
Serial.print("AT+CMGS="");
Serial.print(phone_no1);// first number
Serial.print(""\r\n");
delay(3000);
Serial.print("hi");
Serial.write(0x1A);
Serial.write(0x0D);
Serial.write(0x0A);
Serial.print("\n");
delay(3000);
digitalWrite(13, HIGH); // turn the LED on (HIGH is the voltage level)
delay(100); // wait for a second
digitalWrite(13, LOW); // turn the LED off by making the voltage LOW
delay(100);
delay(100);
delay(1000); // wait for a second
delay(1000);// wait for a second
Then it is nothing to do with your code and you have a hardware issue.
Please read this:-
How to use this forum
It will tell you how to ask a question properly.
Not likely the reason but why a "Serial.begin(9600);" in loop()? The one in Setup() ougth to be enough.
