Having issues implementing an array to detect change in pin states
First post! I certainly hope I posted this in the right section.
Project goal: This is a section of code I'm trying to get working as part of my project. The deliverables are to poll a set of inputs and then send a serial string through Bluetooth when a button is pressed. I'm using a Bluetooth terminal on my phone and it has made troubleshooting easier. The issue I am trying to avoid is flooding the serial port and only send a string when there is pin state change.
Hardware setup:
  • Arduino Due
  • HC 05 Bluetooth connected to serial lines
  • Raspberry Pi (to receive string)
  • I have 2 pushbuttons on the input with pull down resistors. I checked them with an Oscilloscope and the signals are clean. I also ran code to make sure I was getting the inputs fine.
My current project involves looking at only 2 inputs at the moment but I wrote code to be able to scale it up to multiple inputs on my board, which is why I opted to use arrays. Initially I was using functions to sum the array and compare it, but it didn't work because each loop would just add to the sum, so I abandoned it. I didn't figure out a way to reset the array. I switched it up to compare each array element with this current implementation:
#define pin1 53
#define pin2 51
#define Maxnum 2
int currArray[Maxnum];
int prevArray[Maxnum];
int pinx1 = pin1;
int pinx2 = pin2;
int pinArray[Maxnum]={pinx1,pinx2};
    pinMode(pin1,INPUT);
    pinMode(pin2,INPUT);
}//end setup
void readarray(){
  int i;
  for (i=0;i<Maxnum;i++){
    currArray[i] = digitalRead(pinArray[i]);
    //if the current array elements are equal to past array
      for(i=0;i<Maxnum;i++){
        prevArray[i]=currArray[i];
        if (comparearray(currArray,prevArray) == 1){
            pinchange();
  }//end read array
char comparearray(int currArray[],int prevArray[]){
  int i;
    if (currArray[i]!= prevArray[i]){//change back to not equal
      Serial.println("In comparearray");//did not print here, when condition is set to equal, it goes in the routine
      return 1;
}//end compare array
void pinchange(){//detect a change in pin states
    if(pin1 == HIGH){
      Serial.write("<Pin_1_on>");
      else if (pin1 == LOW){
      Serial.write("<Pin_1_off>");
      }//end pin1
  if(pin2 == HIGH){
      Serial.write("<Pin_2_on>");
      else if(pin2 == LOW){
      Serial.write("<Pin_2_off>");
      }//end pin2
}//pinchange
readarray();
}//end main program loop
Please let me know if I need to clarify anything.
this wheel has been invented: GitHub - ubidefeo/FTDebouncer: Debounce and Pin Change handling Library for Arduino
Thank you that is pretty much the kind of thing I'm looking for! I will dig into using that library. In all my google-fu I didn't come across this.
