Sorry im very new to Arduinos but im currently trying to get some code i found online for a led matrix controller using the software jinx led controler, the video i was following doesnt show any of the codeing or software parts but they listed the code for the project claiming it works. when i use the same code i get a "D6" was not declared in this scope when i try to compile it.
the code is
#include <ESP8266WiFi.h>
#include <WiFiUdp.h>
#ifdef AVR
#include <avr/power.h>
#endif
#define PIN D6 //output pin D1
#define NUMPIXELS 100 //number of pixels to control
Adafruit_NeoPixel pixels = Adafruit_NeoPixel(NUMPIXELS, PIN, NEO_GRB + NEO_KHZ800);
const char* ssid = "COGECO-91D6"; //wifi name
const char* password = "314580764688"; //clave router
IPAddress ip(192, 168, 0, 200 );
IPAddress gateway(192, 168, 0, 1);
IPAddress subnet(255, 255, 255, 0);
unsigned int localPort = 65506; // local port to listen for UDP packets
const int PACKET_SIZE = 1357;
byte packetBuffer[PACKET_SIZE]; //buffer to hold incoming and outgoing packets
// A UDP instance to let us send and receive packets over UDP
WiFiUDP udp;
typedef struct
byte r;
byte g;
byte b;
} colorpin;
colorpin led;
int led_index = 0;
void WiFiEvent(WiFiEvent_t event)
switch (event)
case WIFI_EVENT_STAMODE_GOT_IP:
pixels.begin();
case WIFI_EVENT_STAMODE_DISCONNECTED:
// Serial.begin(115200);
WiFi.disconnect(true);
WiFi.onEvent(WiFiEvent);
WiFi.config(ip, gateway, subnet);
WiFi.begin(ssid, password);
while (WiFi.status() != WL_CONNECTED)
// Serial.print("x");
// Serial.println("");
// Serial.println("WiFi connected");
// Serial.println("IP address: ");
// Serial.println("Starting UDP");
udp.begin(localPort);
// Serial.print("Local port: ");
// Serial.println(udp.localPort());
int cb = udp.parsePacket();
if (!cb)
// Serial.setDebugOutput(true);
// We've received a packet, read the data from it
udp.read(packetBuffer, PACKET_SIZE); // read the packet into the buffer
if (cb >= 6 && packetBuffer[0] == 0x9C)
// header identifier (packet start)
byte blocktype = packetBuffer[1]; // block type (0xDA)
unsigned int framelength = ((unsigned int)packetBuffer[2] << 8) | (unsigned int)packetBuffer[3]; // frame length (0x0069) = 105 leds
// Serial.print("Frame.");
// Serial.println(framelength); // chan/block
byte packagenum = packetBuffer[4]; // packet number 0-255 0x00 = no frame split (0x01)
byte numpackages = packetBuffer[5]; // total packets 1-255 (0x01)
if (blocktype == 0xDA)
// data frame ...
// Serial.println("command");
int packetindex;
if (cb >= framelength + 7 && packetBuffer[6 + framelength] == 0x36)
// header end (packet stop)
//Serial.println("s:");
int i = 0;
packetindex = 6;
if (packagenum == 1)
led_index = 0;
while (packetindex < (framelength + 6))
led.r = ((int)packetBuffer[packetindex]);
led.g = ((int)packetBuffer[packetindex + 1]);
led.b = ((int)packetBuffer[packetindex + 2]);
pixels.setPixelColor(led_index, led.r, led.g, led.b);
led_index++;
Serial.println(led_index);
packetindex += 3;
// Serial.print(packagenum);
// Serial.print("/");
// Serial.println(numpackages);
if ((packagenum == numpackages) && (led_index == NUMPIXELS))
pixels.show();
led_index == 0;
and the error code was:
Arduino: 1.8.15 (Windows 10), Board: "Generic ESP8266 Module, 80 MHz, Flash, Disabled (new aborts on oom), Disabled, All SSL ciphers (most compatible), 32KB cache + 32KB IRAM (balanced), Use pgm_read macros for IRAM/PROGMEM, dtr (aka nodemcu), 26 MHz, 40MHz, DOUT (compatible), 1MB (FS:64KB OTA:~470KB), 2, nonos-sdk 2.2.1+100 (190703), v2 Lower Memory, Disabled, None, Only Sketch, 115200"
WiFiManualWebServer:7:24: error: 'D6' was not declared in this scope
7 | #define PIN D6 //output pin D1
C:\Users\natha\AppData\Local\Temp\arduino_modified_sketch_638612\WiFiManualWebServer.ino:10:57: note: in expansion of macro 'PIN'
10 | Adafruit_NeoPixel pixels = Adafruit_NeoPixel(NUMPIXELS, PIN, NEO_GRB + NEO_KHZ800);
exit status 1
option enabled in File -> Preferences.
