Hello. Lately I was trying to use the ESP32 with the Arduino IDE to play around with WiFi Webservers and vice versa sending Webserver Requests with it as I plan to use this in a future project.
My issue is that 4/5 times the data sent by the Webclient Code via a POST Call is not received properly. I tried using Postman (application for sending test http Calls) and doing basically the same as with the Webclient Sketch and everything worked perfectly fine every time.
Note: My issue has nothing to do with JSON or the JSON Library I am using (that's a whole other issue
but my webserver is unable to receive the data my client should send.
Here is my Webserver Code:
// Load Wi-Fi library
#include <WiFi.h>
#include <ArduinoJson.h>
// Replace with your network credentials
const char* ssid = "<changed for privacy>";
const char* password = "<changed for privacy>";
// Set web server port number to 5000
WiFiServer server(5000);
// Variable to store the HTTP request
String header;
DynamicJsonDocument json_data_http(1024);
// Current time
unsigned long currentTime = millis();
// Previous time
unsigned long previousTime = 0;
// Define timeout time in milliseconds (example: 2000ms = 2s)
const long timeoutTime = 2000;
Serial.println("Webserver Example");
// Connect to Wi-Fi network with SSID and password
Serial.print("Connecting to ");
Serial.println(ssid);
WiFi.begin(ssid, password);
Serial.print(".");
// Print local IP address and start web server
Serial.println("");
Serial.println("WiFi connected.");
server.begin();
void loop(){
WiFiClient client = server.available(); // Listen for incoming clients
if (client) { // If a new client connects,
previousTime = currentTime;
Serial.println("New Client."); // print a message out in the serial port
String currentLine = ""; // make a String to hold incoming data from the client
while (client.connected() && currentTime - previousTime <= timeoutTime) { // loop while the client's connected
if (client.available()) { // if there's bytes to read from the client,
char c = client.read(); // read a byte, then
Serial.write(c); // print it out the serial monitor
header += c;
if (c == '\n') { // if the byte is a newline character
// if the current line is blank, you got two newline characters in a row.
// that's the end of the client HTTP request, so send a response:
if (currentLine.length() == 0) {
// HTTP headers always start with a response code (e.g. HTTP/1.1 200 OK)
// and a content-type so the client knows what's coming, then a blank line:
client.println("Content-type:text/json");
client.println("Connection: close");
client.println();
String body_data = "";
while(client.available()){
char c = (char)client.read();
body_data += c;
Serial.print(c);
if (body_data.length() > 0) {
Serial.print("Body Data: ");
Serial.println(body_data);
deserializeJson(json_data_http, body_data);
if (header.indexOf("POST /test") >= 0) {
Serial.println("POST /test");
client.println("done");
// The HTTP response ends with another blank line
client.println();
// Break out of the while loop
} else { // if you got a newline, then clear currentLine
currentLine = "";
} else if (c != '\r') { // if you got anything else but a carriage return character,
currentLine += c; // add it to the end of the currentLine
// Clear the header variable
header = "";
// Close the connection
client.stop();
Serial.println("Client disconnected.");
Serial.println("");
Note: the ArduinoJson Library is for later use in handling sent JSON Data. The "serializeJson" is basically for printing purposes.
The purpose of this sketch is to receive and print out the data that is being sent by the client.
And here is the Webclient Code:
#include <WiFi.h>
#include <HTTPClient.h>
const char* serverName = "http://192.168.1.110:5000/test";
Serial.println("HTTP Request Example");
Serial.print(".");
Serial.println("");
void loop(){
HTTPClient http;
Serial.print("sending ");
Serial.println(serverName);
http.begin(serverName);
http.addHeader("Content-Type", "application/json");
int httpResponseCode = http.POST("{\"address\": \"192.168.1.110\"}");
String payload = http.getString();
Serial.println(httpResponseCode);
Serial.println(payload);
http.end();
delay(2000);
The purpose of this sketch is to send a http POST Call every 2 seconds with some JSON data as payload.
