having problem in programming to show current date
there is no problem when compiling but nothing shows on display. Could anybody help me with it?
#include <LiquidCrystal.h>
#include <Time.h>
#define TIME_MSG_LEN 11 // time sync to PC is HEADER followed by Unix time_t as ten ASCII digits
#define TIME_HEADER 'T' // Header tag for serial time sync message
#define TIME_REQUEST 7 // ASCII bell character requests a time sync message
// T1262347200 //noon Jan 1 2010
LiquidCrystal lcd(12, 11, 10, 6, 4, 3, 2);
void loop(){
if(Serial.available() )
processSyncMessage();
if(timeStatus() == timeNotSet)
Serial.println("waiting for sync message");
digitalClockDisplay();
void printDigits(int digits){
// utility function for digital clock display: prints preceding colon and leading 0
Serial.print(":");
if(digits < 10)
Serial.print('0');
Serial.print(digits);
void processSyncMessage() {
// if time sync available from serial port, update time and return true
while(Serial.available() >= TIME_MSG_LEN ){ // time message consists of header & 10 ASCII digits
char c = Serial.read() ;
Serial.print(c);
if( c == TIME_HEADER ) {
time_t pctime = 0;
for(int i=0; i < TIME_MSG_LEN -1; i++){
c = Serial.read();
if( c >= '0' && c <= '9'){
pctime = (10 * pctime) + (c - '0') ; // convert digits to a number
setTime(pctime); // Sync Arduino clock to the time received on the serial port
void digitalClockDisplay(){
// digital clock display of the time
Serial.print(" ");
Serial.print(day());
lcd.setCursor(0,0);
lcd.print(day(),DEC);
Serial.print(" ");
Serial.print(month());
lcd.setCursor(3,0);
lcd.print(month(),DEC);
Serial.print(" ");
Serial.print(year());
lcd.setCursor(6,0);
lcd.print(year(),DEC);
date.ino (1.82 KB)
How about trying something a bit simpler at first to make sure that your display is wired properly?
//LiquidCrystal lcd(RS, E, D4, D5, D6, D7);
LiquidCrystal lcd(7, 8, 9, 10, 11, 12);      // put your pin numbers here
  lcd.begin(16, 2);                          // put your LCD parameters here
  lcd.print("hello, world!");
  lcd.setCursor(0,1)
  lcd.print("it works!");
Don
Yeah! I tried this and my display works well
check the pins you have connected for the LCD are the same as the ones for the Hello World one.
The reason I say that is that you have defined LiquidCrystal lcd(12, 11, 10, 6, 4, 3, 2); <<<< 7 pins
in your sketch but the Hello World one has LiquidCrystal lcd(7, 8, 9, 10, 11, 12); <<<< 6 pins
so you may just have it defined differently to how it is connected.
I would suggest you copy and paste what you have for the Hello World sketch and then re-connect the pins of the arduino to your LCD to correspond.
hth
Norman
void loop(){
Nothing happens on your display ?
Comment out the first line in that loop:
void loop(){
/*  if(Serial.available() )
You should see the "waiting for sync message" message on your screen.
What other hardware (Arduino) do you use ?
There is no reason to always use the same pins for an LCD display and there are provisions for using 6, 7, 10 or 11 connections between the LCD and the Arduino. That is why the comment says: "// put your pin numbers here".
This information is documented but the documentation is hard to find, and there is only one poor example that does not really explain the syntax. Look here: --> LiquidCrystal - Arduino Reference
Don
Are you having problem with your 'screen' which I would interpret as the serial monitor, with your 'display' which I would interpret as the LCD, or both?
Don
I commetted out the serial instructions in your code, set c to a dummy value and changed the lcd declaration as Norman said. If today was January 1, 1970 your code would be perfect.
