hi.
I have a problem with my project.
I want to put inturrupt in my code but it always ended with fleezing.
and still I couldnt figured out what is wrong with the code.
Can someone help me?
My code is below :
// signal the nRF24 if the PIR senses nearby person
// LEDs and Serial lines are for the test
#include <util/atomic.h>
#include <SPI.h> // Include SPI Code Library which can be downloaded below
#include <nRF24L01.h> // Include NRF24L01 Code Library which can be downloaded below
#include <RF24.h> // Inlcude NRF24 Code Library which can be downloaded below
volatile byte changed = 0;
int msg[1];
const int PIR = 2; // Declare PIR pin
const int red = 6; // Declare red LED pin
const int green = 5; // Declare green LED pin
const int blue = 4; // Declare blue LED pin
const int value1 = 0; //
RF24 radio(7,8); // The NRF24L01 Pin CE and Pin CSN
const uint64_t pipe = 0xA8E8F0F0E1LL; // Communication Pip Address
volatile int PIRstate = 0;
pinMode(LED_BUILTIN, OUTPUT);
pinMode(PIR, INPUT);
pinMode(green, OUTPUT);
pinMode(red, OUTPUT);
pinMode(blue, OUTPUT); // PIR
attachInterrupt(digitalPinToInterrupt(2), toggle, RISING);
Serial.println("Waiting..");
digitalWrite(blue, HIGH);
delay(200);
digitalWrite(blue, LOW);
if (changed == 1) {
// toggle() has been called from interrupts!
// Reset changed to 0
changed = 0;
delay(200);
void toggle() {
msg[0] = 111; // Send the 111 to the reciever
radio.write(msg, 1);
digitalWrite(red, LOW);
digitalWrite(green, HIGH);
changed = 1;
//reference
//nRF24L01
//https://m.blog.naver.com/roboholic84/221139363425
//https://www.14core.com/wiring-the-nrf24l01-2-4ghz-radio-as-remote-switching/
//https://blog.naver.com/twophase/221122054270
//https://m.blog.naver.com/PostView.naver?isHttpsRedirect=true&blogId=twophase&logNo=221122351663
//https://m.blog.naver.com/twophase/221132324612
//PIR
//https://fishpoint.tistory.com/6399
//Ultra sonic
//https://m.blog.naver.com/PostView.naver?isHttpsRedirect=true&blogId=boilmint7&logNo=220926404472
//Interrupt function
//https://mechanic-workshop.tistory.com/m/16
//https://m.blog.naver.com/PostView.naver?isHttpsRedirect=true&blogId=roboholic84&logNo=220421863761
//https://juahnpop.tistory.com/84
//https://engineerparkbro.tistory.com/30
//https://makersportal.com/blog/2019/5/27/arduino-interrupts-with-pir-motion-detector
//https://www.allaboutcircuits.com/technical-articles/using-interrupts-on-arduino/
//https://forum.arduino.cc/t/problem-using-sleep-mode/695188/3
//https://www.arduino.cc/reference/en/language/variables/variable-scope-qualifiers/volatile/
