Having problems combining SD card, BMP 280, and MPU 6050 code
I'm trying to combine 2 files: one that saves temperature and pressure from the BMP 280 onto an SD card, and one that finds acceleration with the MPU 6050. Both codes work fine independently but when I copy and paste the code from one of the files into the other it doesn't work.
SD Card and BMP280 Code:
#include <Wire.h>
  #include <SPI.h>
  #include <SD.h>
  #include <Adafruit_BMP280.h>
  File myFile;
  Adafruit_BMP280 bmp; // use I2C interface
  Adafruit_Sensor *bmp_temp = bmp.getTemperatureSensor();
  Adafruit_Sensor *bmp_pressure = bmp.getPressureSensor();\
  const int BUZZER = 2;
  while (!Serial) {
  ; // wait for serial port to connect. Needed for native USB port only
  Serial.print("Initializing SD card...");
  if (!SD.begin(10)) {
  Serial.println("initialization failed!");
  while (1);
  unsigned status;
  //status = bmp.begin(BMP280_ADDRESS_ALT, BMP280_CHIPID);
  status = bmp.begin();
  if (!status) {
    Serial.println(F("Could not find a valid BMP280 sensor, check wiring or "
                      "try a different address!"));
    while (1) delay(10);
  /* Default settings from datasheet. */
  bmp.setSampling(Adafruit_BMP280::MODE_NORMAL,     /* Operating Mode. */
                  Adafruit_BMP280::SAMPLING_X2,     /* Temp. oversampling */
                  Adafruit_BMP280::SAMPLING_X16,    /* Pressure oversampling */
                  Adafruit_BMP280::FILTER_X16,      /* Filtering. */
                  Adafruit_BMP280::STANDBY_MS_500); /* Standby time. */
  Serial.println("initialization done.");
  sensors_event_t temp_event, pressure_event;
  bmp_temp->getEvent(&temp_event);
  bmp_pressure->getEvent(&pressure_event);
  // nothing happens after setup
  // open the file. note that only one file can be open at a time,
  // so you have to close this one before opening another.
  myFile = SD.open("BMP_data.txt", FILE_WRITE);
  // if the file opened okay, write to it:
  if (myFile) {
    myFile.print(temp_event.temperature);
    myFile.print(" *C, ");
    myFile.print(pressure_event.pressure);
    myFile.println(" hPa.");
    Serial.print(temp_event.temperature);
    Serial.print(" *C, ");
    Serial.print(pressure_event.pressure);
    Serial.println(" hPa");
  // close the file:
    myFile.close();
  // if the file didn't open, print an error:
  Serial.println("error opening test.txt");
MPU 6050 Code (from Adafruit MPU 6050 library):
// Basic demo for accelerometer readings from Adafruit MPU6050
#include <Adafruit_MPU6050.h>
#include <Adafruit_Sensor.h>
#include <Wire.h>
Adafruit_MPU6050 mpu;
void setup(void) {
  while (!Serial)
    delay(10); // will pause Zero, Leonardo, etc until serial console opens
  Serial.println("Adafruit MPU6050 test!");
  // Try to initialize!
  if (!mpu.begin()) {
    Serial.println("Failed to find MPU6050 chip");
    while (1) {
      delay(10);
  Serial.println("MPU6050 Found!");
  mpu.setAccelerometerRange(MPU6050_RANGE_8_G);
  Serial.print("Accelerometer range set to: ");
  switch (mpu.getAccelerometerRange()) {
  case MPU6050_RANGE_2_G:
    Serial.println("+-2G");
  case MPU6050_RANGE_4_G:
    Serial.println("+-4G");
  case MPU6050_RANGE_8_G:
    Serial.println("+-8G");
  case MPU6050_RANGE_16_G:
    Serial.println("+-16G");
  mpu.setGyroRange(MPU6050_RANGE_500_DEG);
  Serial.print("Gyro range set to: ");
  switch (mpu.getGyroRange()) {
  case MPU6050_RANGE_250_DEG:
    Serial.println("+- 250 deg/s");
  case MPU6050_RANGE_500_DEG:
    Serial.println("+- 500 deg/s");
  case MPU6050_RANGE_1000_DEG:
    Serial.println("+- 1000 deg/s");
  case MPU6050_RANGE_2000_DEG:
    Serial.println("+- 2000 deg/s");
  mpu.setFilterBandwidth(MPU6050_BAND_21_HZ);
  Serial.print("Filter bandwidth set to: ");
  switch (mpu.getFilterBandwidth()) {
  case MPU6050_BAND_260_HZ:
    Serial.println("260 Hz");
  case MPU6050_BAND_184_HZ:
    Serial.println("184 Hz");
  case MPU6050_BAND_94_HZ:
    Serial.println("94 Hz");
  case MPU6050_BAND_44_HZ:
    Serial.println("44 Hz");
  case MPU6050_BAND_21_HZ:
    Serial.println("21 Hz");
  case MPU6050_BAND_10_HZ:
    Serial.println("10 Hz");
  case MPU6050_BAND_5_HZ:
    Serial.println("5 Hz");
  Serial.println("");
  delay(100);
  /* Get new sensor events with the readings */
  sensors_event_t a, g, temp;
  mpu.getEvent(&a, &g, &temp);
  /* Print out the values */
  Serial.print("Acceleration X: ");
  Serial.print(a.acceleration.x);
  Serial.print(", Y: ");
  Serial.print(a.acceleration.y);
  Serial.print(", Z: ");
  Serial.print(a.acceleration.z);
  Serial.println(" m/s^2");
  Serial.print("Rotation X: ");
  Serial.print(g.gyro.x);
  Serial.print(g.gyro.y);
  Serial.print(g.gyro.z);
  Serial.println(" rad/s");
  Serial.print("Temperature: ");
  Serial.print(temp.temperature);
  Serial.println(" degC");
  Serial.println("");
This is the combined code I've been trying:
#include <Wire.h>
#include <SPI.h>
#include <SD.h>
File myFile;
void setup(void) {
  while (!Serial)
  if (!mpu.begin()) {
    while (1) {
      delay(10);
  Serial.println("");
  delay(100);
// ************************** SD CARD AND TEMP SENSOR ***********************************
  while (1);
  unsigned status;
  if (!status) {
  Serial.println("");
//  ******************************  SD CARD AN TEMP SENSOR  **********************************
  if (myFile) {
  // close the file:
    myFile.close();
I can't really see how this relates to https://forum.arduino.cc/c/using-arduino/avrdude-stk500-bootloader-issues/81and hence your topic has been moved to a more suitable location on the forum.
Thanks for using code tags in your first post :+1:
Please describe what that means, Does it not compile? Or do you have problems at run time? Please describe what you expect your code to do.
