Hello I'm having problems with wiring up and setting up the 16x32 RGB panel using a arduino uno board. I tried the adafruit learning link on the panel here. I did get the libraries correct and i tried to figure out the wiring but it looks like I might be wrong. So i searched online and found this wiring setup
it looks like mostly what is on adafruit page so i followed the purple color for Arduino uno and again it didn't work. I also saw the LAT pin is on A3 and in the example sketches it is on D10 So i changed that But nothing happen i tried to recycle the power both on the arduino and panel. I really need help can someone please help me and let me know what Am i going wrong please?
I'm not even sure if it is coding or wiring i really need help. Can someone please help me?
Hello MorganS i post many codes in arduino forum but it says it's over the 9000 limit.
EDIT: let me post a small sketch of it.
#include "Adafruit_GFX.h" // Core graphics library
#include "RGBmatrixPanel.h" // Hardware-specific library
#define CLK 8 // MUST be on PORTB!
#define LAT A3
#define OE 9
#define A A0
#define B A1
#define C A2
// Last parameter = 'false' disable double-buffering
RGBmatrixPanel matrix(A, B, C, CLK, LAT, OE, false);
matrix.begin();
// fill the screen with red
matrix.fillRect(0, 0, 32, 16, matrix.Color333(7, 0, 0));
// fill the screen with green
matrix.fillRect(0, 0, 32, 16, matrix.Color333(0, 7, 0));
// fill the screen with blue
matrix.fillRect(0, 0, 32, 16, matrix.Color333(0, 0, 7));
// fill the screen with white
matrix.fillRect(0, 0, 32, 16, matrix.Color333(7, 7, 7));
// fill the screen with black
matrix.fillScreen(matrix.Color333(0, 0, 0));
i just found this online today and should be the same.
Hello MorganS that is not my code that is the example one coming from the Adafruit github example page. I can not get it to work. Nothing displays. If i disconnect the ground wires from the panel .I can random flashes of different colors on different panels and that is that. But if everything is wired up Blank nothing comes up on the Panel at all.
Hello i found my problem one of the pin the LAT pin i was putting to ground and a ground pin i was putting to D10 so it was messing with the arduino and now it works.
