Having problems with connecting nodemcu to google firebase
Hello...I am trying to connect my nodemcu to google firebase for a project... the code is not compiling. it is showing this error message
Arduino: 1.8.19 (Windows Store 1.8.57.0) (Windows 10), Board: "NodeMCU 1.0 (ESP-12E Module), 80 MHz, Flash, Disabled, All SSL ciphers (most compatible), 4M (no SPIFFS), v2 Lower Memory, Disabled, None, Only Sketch, 115200"
C:\Users\User\Documents\Arduino\libraries\Firebase_ESP8266_Client\src\rtdb\stream\FB_MP_Stream.cpp: In member function 'bool MultiPathStreamData::get(const String&)':
C:\Users\User\Documents\Arduino\libraries\Firebase_ESP8266_Client\src\rtdb\stream\FB_MP_Stream.cpp:59:11: error: 'class String' has no member named 'clear'
     value.clear();
C:\Users\User\Documents\Arduino\libraries\Firebase_ESP8266_Client\src\rtdb\stream\FB_MP_Stream.cpp:60:10: error: 'class String' has no member named 'clear'
     type.clear();
C:\Users\User\Documents\Arduino\libraries\Firebase_ESP8266_Client\src\rtdb\stream\FB_MP_Stream.cpp:61:14: error: 'class String' has no member named 'clear'
     dataPath.clear();
C:\Users\User\Documents\Arduino\libraries\Firebase_ESP8266_Client\src\rtdb\stream\FB_MP_Stream.cpp: In member function 'void MultiPathStreamData::empty()':
C:\Users\User\Documents\Arduino\libraries\Firebase_ESP8266_Client\src\rtdb\stream\FB_MP_Stream.cpp:133:14: error: 'class String' has no member named 'clear'
     dataPath.clear();
C:\Users\User\Documents\Arduino\libraries\Firebase_ESP8266_Client\src\rtdb\stream\FB_MP_Stream.cpp:134:11: error: 'class String' has no member named 'clear'
     value.clear();
C:\Users\User\Documents\Arduino\libraries\Firebase_ESP8266_Client\src\rtdb\stream\FB_MP_Stream.cpp:135:10: error: 'class String' has no member named 'clear'
     type.clear();
Multiple libraries were found for "SD.h"
 Used: C:\Users\User\Documents\ArduinoData\packages\esp8266\hardware\esp8266\2.5.1\libraries\SD
 Not used: C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.57.0_x86__mdqgnx93n4wtt\libraries\SD
exit status 1
Error compiling for board NodeMCU 1.0 (ESP-12E Module).
option enabled in File -> Preferences.
pls help
Im following this video for reference...
Please read and follow the advice given in the topic How to get the best out of this forum.
You can spell it: Autoformat the code in the IDE, use code tags here, 6:th symbol in this window, </>, and paste.
