Hi all, I'm having problems with getting a brake input. The throttle works no problem but the brake doesn't. If I use Joystick.setBrake(analogRead(A2)); is does work but isn't smooth enough. The brake and throttle use the same hardware and are wired the same (only difference on is on A1 and one is on A2). I've verified that it isn't a hardware problem.
#include "Joystick.h"
Joystick_ Joystick(JOYSTICK_DEFAULT_REPORT_ID,
JOYSTICK_TYPE_JOYSTICK, 0, 0, false, false, true, false, false, false, false, true, false, true, false);
//int RzAxis;
int brake;
int throttle;
Joystick.begin();
//Joystick.setBrake(analogRead(A2));
brake = analogRead(A2);
brake = map(brake,0,50,0,127.5);
Joystick.setBrake(brake);
throttle = analogRead(A1);
throttle = map(throttle,0,50,0,127.5);
Joystick.setThrottle(throttle);
Joystick.sendState();
delay(5);
Update: I'm trying to replace the stock fanatec clubsport V2 (sim racing pedals) electronics with two hall-effect sensors, a loadcell (w amp) and a arduino leonardo. For now I've only conntected the 2 halll sensors (simply to 5v, ground and A1 or A2). In the serial monitor both seem to work fine but in windows one behaves different compared to the other (see video Imgur: The magic of the Internet). In the video I used this code.
//int RzAxis;
int brake;
int throttle;
Joystick.begin();
Joystick.setThrottle(analogRead(A1));
int y1 = analogRead(A1);
int y4 = analogRead(A2);
Serial.print(y1);
Serial.print(" ");
Serial.println(y4);
delay(10);
Update 2: I fixed it by celebrating it in windows.
