So i am trying to make the fan speed change with the temperature, i mapped the temperature readings from 50-100 celsius to 50-255 into fanSpeed pwm, the code works fine in the ranges 50-100 celsius, but when it goes below 50 instead of fanSpeed going to 0 by the if function i wrote it goes below 50 and at around 30 celsius it goes into negative values and if i set unsigned int it overflows and goes to 65500, any idea how to fix this and why the if functions aren't working?, in the void loop i'm just calling the void fan
code:
void fan() //loop for automatic fan speed temperature control
pinMode(fanPin, OUTPUT); //sets fanPin as output
if (currentTemperature < 50)
fanSpeed = 0;
if (currentTemperature > 100)
fanSpeed = 255;
fanSpeed = map(currentTemperature, 50, 100, 50, 255); //maps currentTemperature from 50-100 to 50-255 for automatic variable fan speed control and it saves the value to fanSpeed
analogWrite(fanPin, fanSpeed); //outputs fanSpeed value(0-255) to fanPin
