Good day,
So I'm new to Arduino but I've been working with automation for a while now...
I used to buy a bunch of DT-06 DOIT TTL-Wifi module from amazon for a reasonable price and they've been working well over the time. But I had some issues with one (basically I was getting some garbage on the ttl port so I tried to reflash it. Since then, device is dead... No led no nothing....
The only thing I can do is to put it in flashmode again and push a firmware to it... But as you guess, I can't find any appropriate firmware for it and the device is probably a clone and not binaries I've found on DOIT forums are working... That why I'm sollicitating your help ![]()
this is what esptool tells me about it:
Detecting chip type... ESP8266
Chip is ESP8285
Features: WiFi, Embedded Flash
Crystal is 26MHz
MAC: 84:0d:8e:zz:zz:zz
Uploading stub...
Running stub...
Stub running...
Manufacturer: 51
Device: 4014
Detected flash size: 1MB
Hard resetting via RTS pin...
Could anyone help me recover this little guy ?
I even tried to dump the firmware from another one to this one without success ![]()
