having syntax issues
help!!! i am used to c#…and i am getting the following error:
In function ‘void doRGB(char*, int)’:
error: ISO C++ forbids comparison between pointer and integer In function ‘boolean checkfor2commas(char*, int)’:
code:
#define STRLEN 16
char buffer[STRLEN];
int bufferIndex = 0;
int writer[2]={0,200};
int redPin = 11;
int bluePin= 9;
int greenPin = 10;
if( Serial.available())
char ch = Serial.read();
if( ch == ‘\r’)
buffer[ bufferIndex ] = 0;
if(checkfor2commas(buffer,bufferIndex));
doRGB(buffer,bufferIndex);
bufferIndex = 0;
buffer[ bufferIndex++ ] = ch;
void doRGB(char buff,int size)
int comcount = 0;
int r = 0;
int g = 0;
int b = 0;
for (int x = 0;x<size;x++)
if(buff == “,”)
comcount++;
switch(comcount)
case 0:
r = (r * 100) + int(buff);
case 1:
g = (g * 100) + int(buff);
case 2:
b = (b * 100) + int(buff);
color(r,g,b);
boolean checkfor2commas(char buff,int size)
int comcount = 0;
if(buff==",")
comcount++;
if (comcount == 2)
return true;
return false;
void color (unsigned int red, unsigned int green, unsigned int blue)
analogWrite(redPin, 255-red);
analogWrite(bluePin, 255-blue);
analogWrite(greenPin, 255-green);
Serial.print(red);
Serial.print(",");
Serial.print(blue);
Serial.print(",");
Serial.println(green);
The double quoted comma (",") in C/C++ is a constant zero terminated string and a reference to this is a pointer. As such the compiler does not make sense of a comparison between a single character (buff[x]) and a pointer.
Change the double quotes to single quotes (',' is a character constant) and you should be ok.
 if(buff[x]==",")
aaahhh...you are talking to a .Net programmer...it makes sense now
It is actually the same in .NET, but the compiler/interpreter will add the necessary type conversion for you (character to string and then a string compare). C/C++ however is less forgivng in this respect.
