Having to select serial monitor twice is driving me crazy!
Hi. This is my first post so please forgive any daft questions I ask.
I'm using the Arduino 2.0.4 on a Mac running Ventura.
I have to select "serial monitor" twice before it opens. That's every time I use it.
Is anyone else having this problem and if so any suggestions?
Thanks
Have you tried the Mac equivalent of PC CTRL-SHFT-M? (you should find the Mac equivalent under IDE >> TOOLS >> Serial Monitor (and next to it is the hotkey)
Thanks you :slight_smile: That's saved me from pulling out the little hair I have left
Not being able to pop out the serial monitor makes it unusable for me. Too frustrating.
Until the Serial Monitor is made a separate window, which is on the development list, just open a second copy of the IDE with the same COM port selected and use that as your Serial monitor
You then have to toggle which one is active which is still frustrating. 1.18.X is much more user friendly still IMO.
No toggling needed. Just leave the Serial monitor open in the second instance of the IDE and you will see the output even if the first instance currently has the focus
Hi @oldlarko
Where exactly in the Arduino IDE interface are you selecting it?
Tools -> Serial Monitor
I have to always do this twice for the seial monitor to open.
Is there a reason why you don't use the Serial Monitor icon, top/right of the screen ?
Because I'm dumb.:slight_smile: That works as it says on the tin.
I used the old IDE previously and was used to accessing via the menu.
Even the old IDE has an icon for the Serial Monitor top/right of the screen. There was never a need to use the menu and you can open it in both using the Ctrl+Shift+M keyboard shortcut
Having said that, I am glad that you are sorted
It sounds like the problem is that the Serial Monitor is already open, but is not selected in the bottom panel of the Arduino IDE window. The bottom panel is a container for "views". When multiple views are open, a view can be made visible by clicking its tab on the bottom panel (similar to tabs in your web browser).
For example, I have two views open in the bottom panel:
  • Output
  • Serial Monitor
The Output view is currently selected, so if I want to switch to the "Serial Monitor" view, I just click on its tab:
Thanks :slightly_smiling_face:
