I started using an 16x2 LCD today.
But the problem is i sometimes i have to upload the code many times.
Why i have to do this is because i get wierd symbols in the display on some uploads.
For example, one time i might try to display "Hello"
and would get "QD4" or something like that.
So i upload a few more times and after some attempts it works.
Anyone know what it could be?
Im pretty sure i wired it correctly, and it is working "most of the time"
Sometimes i will get "Hello World" on the screen.
Other times ill get strange signs.
And i dont even have to reupload for this to happen.
If i just press the "reset button" on the arduino.
It will flip between "Hello World" and "Strange Signs" (always the same strange signs)
Sometimes it might be "Hello World" a few times in a row when resetting.
And sometimes the signs.
Because there is no inductive load such as a relay or a motor or a pump in that circuit.
The code in your original post most likely works all the time since there is no pump involved.
I didn't see any evidence of the words "Hello World" in your video which obviously uses different code as well as additional hardware -- something you neglected to mention.
A photograph of your actual setup.
A copy/paste version of the code that you are actually using.
A photograph of the characters that are actually being displayed by the above mentioned hardware and software.
The 'nibble shift' problem is likely due to a somewhat out of spec LCD controller and will probably not be fixed by tinkering with the wiring (other than by adding four more wires and using an 8-bit interface).
Your display will probably work if you use a library that is designed to deal with these low quality displays. One such library was actually written for 40x4 displays but will work with your 16x2.
I have tried using liquidcrystal440 but i cant fix the code.
First it gave me error of a return type not being the same as the overriden version.
I managed to fix that error.
But then i got errors that WProgram.h could not be found.
Gobaz:
I don't think that you followed the downloads link to get to the latest version since the updated program is NOT called 'liquidcrystal440'.
Have you tried the 8-bit mode? Note: You will have to use the original library to do this since the liquidcrystal440 library and it's successor do not support the 8-bit mode.
