Having troble with one of the projects out of the projects book
When I try to verify, it comes up with this error message:exit status 1 expected unqualified-id before numeric constant
What dose this mean and how to I fix it?
What project coming from what projects book? Please post your code in code </> tags so we can help you. :slight_smile:
The project is number 04: Color mixing lamp. When the error code comes up, it highlights line 12. Here is the code:
const int greenLEDin = 9; const int redLEDin = 10; const int blueLEDin = 11;
const int redSensorPin = A1; const int greenSensorPin = A2; const int blueSensorPin = A0; int redValue = 0; int greenValue = 0; int blueValue = 0;
void setup() { Serial.begin(9600); pinMode(greenLED, OUTPUT); pinMode(redLED, OUTPUT) ; pinMode(blueLED, OUTPUT); void loop() { redSensorValue = analogRead(redSensorPin); delay(5); greenSensorValue = analogRead(greenSensorPin); delay(5); blueSensorValue = analogRead(blueSensorPin); Serial.print("Raw Sensor Values /t red: "); Serial.print(redSensorValue); Serial.print("/t green: "); Serial.print(greenSensorValue); Serial.print("/t blue: "); Serial.print(blueSensorValue); redValue = redSensorValue/4; greenValue = greensSensorValue/4; blueValue = blueSensorValue/4;
Serial.print("Mapped Sensor Values /t red: "); Serial.print(redValue) Serial.print("/t green: "); Serial.print(greenValue); Serial.print("/t blue:") Serial.print(blueValue); analogWrite(redLEDin, redValue); analogWrite(greenLEDin, greenValue); analogWrite(blueLEDin, blueValue); }
Please do us all a favour and post the code without useless line number but with code tags as requested
A silly question, but you have not by any chance typed in the line numbers, have you ?
What are code tags? I'm not sure as I am very new to coding.
Yes, I did put in the numbers. I found it easier to follow that way.
When you are writing a reply on this forum, there is a button that looks like this: </> , next to the bold, italics, etc… When you put the code inside of the tags,
it looks like this!
Here are a few issues I spotted so far-
int redValue = 0;
int greenValue = 0;
int blueValue = 0;
int redValue = 0;
int greenValue = 0;
int blueValue = 0;
There’s a few other issues, but can you spot what’s wrong with these?
Oh, for reference to others, this appears to be Project 4 from the Arduino Starter Kit.
Guineapig04:
Take them out. The program will not compile with them in.
The IDE has line numbers of its own if you find them helpful. Turn them on in File/Preferences.
