Having trouble getting two wheels to work
I am trying to get two wheels to work, however when I have one wheel connected, it spins, but then when I connect the other wheel the original wheel spinning stops moving. How do I get both wheels to spin at the same time?
#include <SPI.h> //SPI library for communication with the nRF24L01+
#include “RF24.h” //The main library of the nRF24L01+
#include “Wire.h”
RF24 radio (8, 9); // CE,CSN
//Create a pipe addresses for communication
const uint64_t pipe = 0xE8E8F0F0E1LL;
struct package
int X = 1;
int Y = 1;
typedef struct package Package;
Package pos;
int buttonState;
int spinnerState = false ;
int motora_1 = 3;
int motora_2 = 4;
int motorb_1 = 5;
int motorb_2 = 6;
int spinner = 2;
radio.begin(); //Start the nRF24 communicate
radio.openReadingPipe(1, pipe); //Sets the address of the transmitter to which the program will receive data.
radio.startListening();
pinMode(motora_1, OUTPUT);
pinMode(motora_2, OUTPUT);
pinMode(motorb_1, OUTPUT);
pinMode(motorb_2, OUTPUT);
pinMode(spinner, OUTPUT);
digitalWrite(spinner, LOW);
delay(100);
if (radio.available()) {
radio.read(&pos, sizeof(pos));
radio.read(&buttonState, sizeof(buttonState));
Serial.print(“X:”);
Serial.print(pos.X);
Serial.print(" Y");
Serial.print(pos.Y);
Serial.print(" buttonState");
Serial.println(buttonState);
int xAxis = pos.X;
int yAxis = pos.Y;
int forward = map(yAxis, 570, 1024, 0, 255);
int backward = map(yAxis, 480, 0, 0, 255);
int right = map(xAxis, 570, 1024, 0, 255);
int left = map(xAxis, 480, 0, 0, 255);
if (yAxis > 570) { // Move Forward
// Set Motor A forward
analogWrite(motora_1, forward);
analogWrite(motora_2, 0);
// Set Motor B forward
analogWrite(motorb_1, forward);
analogWrite(motorb_2, 0);
} else if (yAxis < 480) { //Move Backward
// Set Motor A backward
analogWrite(motora_1, 0);
analogWrite(motora_2, backward);
// Set Motor B backward
analogWrite(motorb_1, 0);
analogWrite(motorb_2, backward);
} else if (xAxis > 570) { // Move Right
analogWrite(motora_1, right);
// Set Motor B stop
} else if (xAxis < 480) { // Move Left
// Set Motor A stop
// Set Motor B foward
analogWrite(motorb_1, left);
} else { //stop
// Set Motor A stop
// Set Motor B stop
if (buttonState == 0 ) {
spinnerState = ! spinnerState;
delay(50);
if (spinnerState == true) {
digitalWrite(spinner, HIGH); //turn On spinner
delay(100);
digitalWrite(spinner, LOW); //turn Off spinner
delay(100);
We need a schematic of your wiring. What is the power source for the motors?
Have you written a simple program that just makes one motor work at a time and control the speed?
Please read the forum guidelines and post your code properly.
int motora_1 = 3;
int motora_2 = 4;
int motorb_1 = 5;
int motorb_2 = 6;
If this is an UNO, these are the PWM pins available to you:
Uno, Nano, Mini 3, 5, 6, 9, 10, 11
BTW
In the Arduino IDE, use Ctrl T to format your code then copy the complete sketch.
Use the </> icon from the ‘reply menu’ to attach the copied sketch.
I agree that part of the problem is Pin 4 being used as an analog output pin. It isn’t. Any value below 127 will be OFF and any value above 127 will be ON.
@cvillegas, your topic has been moved to a more suitable section of the forum.
Can you please edit your post, select all code, click the code button image above the edit box and safe your post. It will make it easier to read and copy.
