Hello all,
I'm new to Arduino (and loving it!) and C++, and have hit a stumbling block with a project. I've built a Stainless lamp and connected a capacitive sensor such that it cycles among shades of color (generated by two LED strips, one RGB and one white) when touched(triggered). As a basis, I used Clay Shirky's ColorCrossfader sketch I found here and integrated the capacitive sensor. It works great.
I'd like to, however, replace one of the colors with a function/routine that cycles the LEDs, creating a TV-like effect, until the capacitive sensor is triggered and it fades to the next color. I have the "TV" code working great as it's own sketch... but am having trouble integrating it into this sketch.
I've hit two stumbling blocks:
-I know I'm not calling the function "isButtonPressed" correctly on line 44, but can't figure out to call it correctly;
-I kthink I need to say “if the mode is mode8 then run this (TV) code, otherwise, run the other code"... but am unsure of how to structure it/properly phrase this.
I would be so appreciative of any suggestions!
Thanks and best, Jared
//pin connections
int redPin = 9;
int grnPin = 10;
int bluPin = 11;
int whiPin = 3;
int buttonPin = 2;
int mode1 = 1;
int mode2 = 2;
int mode3 = 3;
int mode4 = 4;
int mode5 = 5;
int mode6 = 6;
int mode7 = 7;
int mode8 = 8;
int mode9 = 9;
int mode10 = 10;
// Color arrays
int modeColor1[4] = { 0, 0, 0, 0 };
int modeColor2[4] = { 100, 100, 100, 0 };
int modeColor3[4] = { 100, 0, 0, 0 };
int modeColor4[4] = { 0, 100, 0, 0 };
int modeColor5[4] = { 0, 0, 100, 0 };
int modeColor6[4] = { 0, 15, 100, 15 };
int modeColor7[4] = { 0, 0, 0, 80 };
void modeColor8() {
do
analogWrite(whiPin, random(200)+10);
delay(random(1200));
analogWrite(redPin, random(70)+35);
delay(random(100));
analogWrite(grnPin, random(150)+35);
delay(random(200));
analogWrite(bluPin, random(230)+35);
delay(random(400));
} while (isButtonPressed() false);
int modeColor9[4] = { 30, 30, 50, 30 };
int modeColor10[4] = { 100, 30, 8, 10 };
int yellow[4] = { 40, 95, 0, 0 };
int dimWhite[4] = { 30, 30, 30, 0 };
int justwhite [4] = {0, 0, 0, 100 };
// etc.
// Set initial color
int redVal = modeColor1[0];
int grnVal = modeColor1[1];
int bluVal = modeColor1[2];
int whiVal = modeColor1[3];
int wait = 5; // 10ms internal crossFade delay; increase for slower fades
int hold = 5; // Optional hold when a color is complete, before the next crossFade
int DEBUG = 1; // DEBUG counter; if set to 1, will write values back via serial
int loopCount = 60; // How often should DEBUG report?
int repeat = 0; // How many times should we loop before stopping? (0 for no stop)
int j = 0; // Loop counter for repeat
// Initialize color variables
int prevR = redVal;
int prevG = grnVal;
int prevB = bluVal;
int prevW = whiVal;
int currentMode = mode6;
boolean currentState = LOW;//storage for current button state
boolean lastState = LOW;//storage for last button state
pinMode(buttonPin, INPUT);//this time we will set the pin as INPUT
pinMode(redPin, OUTPUT);
pinMode(bluPin, OUTPUT);
pinMode(grnPin, OUTPUT);
pinMode(whiPin, OUTPUT);
if (DEBUG) { // If we want to see values for debugging...
Serial.begin(9600);//initialize Serial connection
isButtonPressed();
currentMode = getNextMode(currentMode);
int* colors = getColor( currentMode );
crossFade(colors);
delay(1000);//crude form of button debouncing
boolean isButtonPressed(){
currentState = digitalRead(buttonPin);
if (currentState == HIGH && lastState == LOW){//if button has just been pressed
Serial.println("pressed");
return true;
return false;
int getNextMode(int mode) {
if (mode == mode1) return mode2;
if (mode == mode2) return mode3;
if (mode == mode3) return mode4;
if (mode == mode4) return mode5;
if (mode == mode5) return mode6;
if (mode == mode6) return mode7;
if (mode == mode7) return mode8;
if (mode == mode8) return mode9;
if (mode == mode9) return mode10;
if (mode == mode10) return mode6;
int* getColor(int mode) {
if (mode == mode1) return modeColor1;
if (mode == mode2) return modeColor2;
if (mode == mode3) return modeColor3;
if (mode == mode4) return modeColor4;
if (mode == mode5) return modeColor5;
if (mode == mode6) return modeColor6;
if (mode == mode7) return modeColor7;
if (mode == mode8) return modeColor8;
if (mode == mode9) return modeColor9;
if (mode == mode10) return modeColor10;
int calculateStep(int prevValue, int endValue) {
int step = endValue - prevValue; // What's the overall gap?
if (step) { // If its non-zero,
step = 1020/step; // divide by 1020
return step;
/* The next function is calculateVal. When the loop value, i,
* reaches the step size appropriate for one of the
* colors, it increases or decreases the value of that color by 1.
* (R, G, and B are each calculated separately.)
int calculateVal(int step, int val, int i) {
if ((step) && i % step == 0) { // If step is non-zero and its time to change a value,
if (step > 0) { // increment the value if step is positive...
val += 1;
else if (step < 0) { // ...or decrement it if step is negative
val -= 1;
// Defensive driving: make sure val stays in the range 0-255
if (val > 255) {
val = 255;
else if (val < 0) {
val = 0;
return val;
/* crossFade() converts the percentage colors to a
* 0-255 range, then loops 1020 times, checking to see if
* the value needs to be updated each time, then writing
* the color values to the correct pins.
void crossFade(int color[4]) {
// Convert to 0-255
int R = (color[0] * 255) / 100;
int G = (color[1] * 255) / 100;
int B = (color[2] * 255) / 100;
int W = (color[3] * 255) / 100;
int stepR = calculateStep(prevR, R);
int stepG = calculateStep(prevG, G);
int stepB = calculateStep(prevB, B);
int stepW = calculateStep(prevW, W);
for (int i = 0; i <= 1020; i++) {
redVal = calculateVal(stepR, redVal, i);
grnVal = calculateVal(stepG, grnVal, i);
bluVal = calculateVal(stepB, bluVal, i);
whiVal = calculateVal(stepW, whiVal, i);
analogWrite(redPin, redVal); // Write current values to LED pins
analogWrite(grnPin, grnVal);
analogWrite(bluPin, bluVal);
analogWrite(whiPin, whiVal);
delay(wait); // Pause for 'wait' milliseconds before resuming the loop
if (DEBUG) { // If we want serial output, print it at the
if (i == 0 or i % loopCount == 0) { // beginning, and every loopCount times
Serial.print("Loop/RGB: #");
Serial.print(i);
Serial.print(" | ");
Serial.print(redVal);
Serial.print(" / ");
Serial.print(grnVal);
Serial.println(bluVal);
Serial.println(whiVal);
DEBUG += 1;
// Update current values for next loop
prevR = redVal;
prevG = grnVal;
prevB = bluVal;
prevW = whiVal;
delay(hold); // Pause for optional 'wait' milliseconds before resuming the loop
