having trouble loading sketch
having trouble loading sketch i keep getting this
avrdude: stk500v2_disable(); failed to leave programing mode
following projects out of the book getting started with arduino first one i did loaded but now i am not sure if it loading them at all hears the one i am doing right now.
i am also wondering i want to mount my board but i do not know how i should mount it to or how to space it and what to space it with.
ps. any help and or suggestion will be helpful. and think u in advance for your help.
// turn on led when the button is pressed // and keep it on after it is released // now with a new and improved formula!
const int LED = 13; // the pin for the LED const int BUTTON = 7; // the input pin were the // pushbutton is connected int val = 0; // val will be used to store the state // of the input pin int old_val = 0; // this variable stores the previous // value of "val" int state = 0; // LED off and 1 = LED on
void setup(){ pinMode(LED, OUTPUT); // tell arduino LED is an input pinMode(BUTTON, INPUT); // and BUTTON is an input } void loop(){ val = digitalRead(BUTTON); // read input value and store it
// check if there was a transition if ((val == HIGH) && (old_val == LOW)){ state = 1 - state; delay(10); }
old_val = val; // val is now old, let's store it
if (state ==1) { digitalWrite(LED, HIGH); // turn led on } else{ digitalWrite(LED, LOW); } }
