Having trouble on solving the following tasks
All i can say is, thanks a lot for your time and patience for solving this issue with me. I am sorry if i have been harsh trying to solve this problem. But, it's sure is worth to know that the Array usually starts at 0 and ends with 9 if the row is equals to 10, and the column starts with 0 and ends with 1 if the cols is equals to 2.
Thank you a lot for your time and patience with me :). There is another task that i am trying to solve as well, but for now. let me get this code organized.
Yes, ill put the for loops back once im done with arranging my code. Once im done, ill display what i've altered with the output :slight_smile:
The thing to remember here is that the compiled code (when it is that simple and that explicit) rarely lies.
If you see that a result that is being printed when perhaps you don't expect it to be, check and double check the conditions and fit the result to the observation.
I realised as soon as you typed your interpretation of the table values what the problem was, but you found it yourself from my correction, and you gained a valuable lesson about arrays which will stick in your mind better than if I had simply told you.
I'm curious why the values in the 2nd column of the lookup table are in decreasing order. I find it easier to understand when a value is in range when the lookup table is in increasing order.
Here is my modified version of my code: -
const int ThermPin = A0;
const int rows = 10;
const int cols = 2;
int Table[rows][cols] ={   //col 0||col 1
                            { 25, 4470 }, //row 0
                            { 26, 4250 }, //row 1
                            { 27, 4030 }, //row 2
                            { 28, 3800 }, //row 3
                            { 29, 3530 }, //row 4
                            { 30, 3270 }, //row 5
                            { 31, 3200 }, //row 6
                            { 32, 3170 }, //row 7
                            { 33, 3100 }, //row 8
                            { 34, 3070 }  //row 9
float Vin = 5.0;
float ThermResist = 0.0;
float R2 = 10000.0;
float SensorValue = 0.0;
float Vout = 0.0;
  SensorValue = analogRead(ThermPin);
  Serial.print("Value = ");
  Serial.print(SensorValue);
  Vout = (((SensorValue+1)*Vin)/1024.0);
  Serial.print("\t Voltage = ");
  Serial.print(Vout);
  Serial.print(" V");
  ThermResist =((R2*Vin)/Vout)-R2;
  Serial.print("\t Resistance = ");
  Serial.print(ThermResist);
  Serial.println(" Ohm");
  for (int i = 0; i<rows; i++)
   for(int j = 0;j<cols; j++)
      if(ThermResist >= Table[2][1] && ThermResist <= Table[0][1] )
        Serial.print(Table[0][0]);
        Serial.println(" C");
      if(ThermResist >= Table[4][1] && ThermResist <= Table[3][1] )
        Serial.print(Table[3][0]);
      if(ThermResist >= Table[6][1] && ThermResist <= Table[5][1] )
        Serial.print(Table[5][0]);
      if(ThermResist >= Table[9][1] && ThermResist <= Table[7][1] )
        Serial.print(Table[9][0]);
    i++;
  j++;
And here is the output to that (Works like a charm :D!): -
Value = 685.00	 Voltage = 3.35 V	 Resistance = 4927.11 Ohm
Value = 688.00	 Voltage = 3.36 V	 Resistance = 4862.12 Ohm
Value = 693.00	 Voltage = 3.39 V	 Resistance = 4755.04 Ohm
Value = 695.00	 Voltage = 3.40 V	 Resistance = 4712.64 Ohm
Value = 698.00	 Voltage = 3.41 V	 Resistance = 4649.50 Ohm
Value = 701.00	 Voltage = 3.43 V	 Resistance = 4586.89 Ohm
Value = 704.00	 Voltage = 3.44 V	 Resistance = 4524.82 Ohm
Value = 707.00	 Voltage = 3.46 V	 Resistance = 4463.28 Ohm
25 C
25 C
25 C
25 C
25 C
25 C
25 C
Value = 729.00	 Voltage = 3.56 V	 Resistance = 4027.40 Ohm
Value = 733.00	 Voltage = 3.58 V	 Resistance = 3950.95 Ohm
Value = 731.00	 Voltage = 3.57 V	 Resistance = 3989.07 Ohm
Value = 739.00	 Voltage = 3.61 V	 Resistance = 3837.84 Ohm
Value = 737.00	 Voltage = 3.60 V	 Resistance = 3875.34 Ohm
Value = 740.00	 Voltage = 3.62 V	 Resistance = 3819.16 Ohm
Value = 742.00	 Voltage = 3.63 V	 Resistance = 3781.96 Ohm
28 C
28 C
28 C
28 C
28 C
28 C
Value = 756.00	 Voltage = 3.70 V	 Resistance = 3527.08 Ohm
Value = 768.00	 Voltage = 3.75 V	 Resistance = 3316.00 Ohm
Value = 769.00	 Voltage = 3.76 V	 Resistance = 3298.70 Ohm
Value = 771.00	 Voltage = 3.77 V	 Resistance = 3264.25 Ohm
30 C
30 C
30 C
30 C
30 C
30 C
Value = 775.00	 Voltage = 3.79 V	 Resistance = 3195.88 Ohm
Value = 776.00	 Voltage = 3.79 V	 Resistance = 3178.89 Ohm
Value = 777.00	 Voltage = 3.80 V	 Resistance = 3161.95 Ohm
34 C
34 C
34 C
34 C
34 C
You're still missing the point of using the for loop to provide you with indices.
How am i suppose to announce the indices that i need to call out the printout that i am looking for (say i need to call out a printout of 25 C with a range between 4030 & 4470) How will i apply that in an index method?
I now cannot work out what you're trying to do.
If you're just filtering for specific values, then you don't need loops at all.
I thought you were using a for loop to give you lookup capabilities, but since you don't use the indices, you're just wasting processing cycles.
I also don't see why you need to iterate over the columns of the table at all.
I see your double increment has crept back in.
AWOL:
I thought you were using a for loop to give you lookup capabilities, but since you don't use the indices, you're just wasting processing cyles.
That's the whole point of having the for loop...is to use it for lookup capabilities as you have mentioned.
i myself, don't like to use for loops as much to be honest with you.
Because, it appears, you do not understand them. They are really quite simple, and very, very useful. I think it would be worth the effort to understand them.
PaulS:
Yes, i do know how to use them..but i don't know why do i need to use indeces for my if statements. This is the major problem that i am currently facing at this moment.
No you don't. If you knew, you'd scream seeing those i++ and j++ repeated at the end of the for code block.
If you don't know why you should use them, then probably you don't need them. :wink:
tuxduino:
What are you on about? i have removed those codes a while ago. and Still prints out the results based on the increments by 4-5 times based on the table.
Also, if i don't need the indeces, then what's the point of using the for loop then :S?
They were still there in the last code you posted. You can hardly expect us to keep trying to help you if you are changing code without telling us.
Please read again your reply #44.
Changing code that you posted a while ago is a dirty trick. Please do not do that again. Post the code in a new reply.
const int cols = 2;
float Vin = 5.0;
float R2 = 10000.0;
float Vout = 0.0;
  Serial.print(Vout);
  Serial.print(" V");
Output of the code(still loops twice as much): -
25 C
25 C
25 C
25 C
25 C
25 C
25 C
28 C
28 C
28 C
28 C
28 C
28 C
30 C
30 C
30 C
30 C
30 C
30 C
34 C
34 C
34 C
34 C
34 C
PaulS:
I've changed the code on reply #44 back to where it was. So don't worry about it. Although, i am still concerned on using the for loop
You've fixed the double index increment issue, but you still pointlessly use two nested for()s just to print the same thing multiple times. And you were the first to recognize you didn't understand why you needed those cycles. Can't you see the indices don't play any role in the code of the inner for() block ?
You either use multiple copy-n-pasted if()s, or you use just one and loop through the table's row. (Hint: you need just one loop).
tuxduino:
The indices doesn't do anything on my for loop. Which is why i don't understand why i need a for loop for this task. It would have made more sense if i knew how to use a one loop routine for my for loop.
