Hello,
I'm a teacher testing out the MakeBlock Ultimate 2.0 robotics kit for use in my high school Advanced Robotics class next year. I really like the hardware, but I'm finding that the electronics and the programming leave something to be desired.
Truly what I want is a way to directly program the MegaPi (or hey some other microcontroller if it turns out MegaPi is a piece of garbage) using the Arduino IDE. I don't want to use mBlock. It's drag-and-drop, which is fine, but that's for Intro to Robotics, not Advanced. I want my kids writing code.
I have already uninstalled the old drivers, then installed the new CH340/341 drivers so my Macbook is no longer crashing when I connect to MegaPi via USB.
So I open the Arduino IDE, and select the following:
Boards > Arduino/Genuino Mega or Mega 2560
Processor > ATmega2560
Port > /dev/cu.wchusbserial1420
Then choose one of the MakeBlock sample code files, like:
...and try to upload it, and I get an error (in comments below). Any help would be appreciated.
HW/SW config:
Ultimate 2.0 kit
MegaPi
Two 25mm Encoder Motors DC 9V, 185rpm
Two encoder modules connected to MegaPi ports 1 and 2
MegaPi and motors are powered using the six cell AA battery pack loaded with six fully charged Duracell NiMH rechargeables
Arduino IDE 1.8.3 with MakeBlock libraries and boards updated
Macbook Pro early 2015, running OSX Sierra 10.12.5
Connecting via USB (I know my USB cable is good because I can download the Blink code. Likewise, I had moderate success with mBlock, and managed to download a couple rudimentary programs.)
avrdude: Version 6.3, compiled on Jan 17 2017 at 12:01:35
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "/Users/JN/Library/Arduino15/packages/arduino/tools/avrdude/6.3.0-arduino9/etc/avrdude.conf"
User configuration file is "/Users/JN/.avrduderc"
User configuration file does not exist or is not a regular file, skipping
Using Port : /dev/cu.wchusbserial1420
Using Programmer : wiring
Overriding Baud Rate : 115200
AVR Part : ATmega2560
Chip Erase delay : 9000 us
PAGEL : PD7
BS2 : PA0
RESET disposition : dedicated
RETRY pulse : SCK
serial program mode : yes
parallel program mode : yes
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Then it repeats a lot of stuff...let me see if I can fit the rest in here:
avrdude: stk500v2_getsync(): timeout communicating with programmer
avrdude: stk500v2_ReceiveMessage(): timeout
avrdude: ser_recv(): read error: Device not configured
avrdude: ser_send(): write error: Device not configured
avrdude: stk500_send(): failed to send command to serial port
avrdude: stk500v2_command(): failed miserably to execute command 0x1b
avrdude: stk500isp_read_byte(): timeout/error communicating with programmer
avr_read(): error reading address 0x0000
read operation not supported for memory "signature"
avrdude: error reading signature data for part "ATmega2560", rc=-2
avrdude: error reading signature data, rc=-1
(snip)
avrdude: stk500v2_command(): failed miserably to execute command 0x11
avrdude: stk500v2_disable(): failed to leave programming mode
ioctl("TIOCMGET"): Device not configured
avrdude: ser_close(): can't reset attributes for device: Device not configured
I've also tried updating the firmware for MegaPi via the Arduino IDE. Here is the error it throws.
avrdude: ser_open(): can't open device "/dev/cu.wchusbserial1420": Resource busy
ioctl("TIOCMGET"): Inappropriate ioctl for device
avrdude: ser_send(): write error: Bad file descriptor
avrdude done. Thank you.
the selected serial port
does not exist or your board is not connected
