Having trouble running two motors at a time when used IRremote.h library
Hey there!
I am using arduino nano along with IR receiving head VS1838B.
I am using library IRremote.h
I have functions in my code which runs the bot in various directions.
For a test I have code in which bot goes forward and it works very well.
When I tried merging separately coded working codes, one motor stops working, which works fine again when I remove IR receiver code.
I tried and pinned out the line which causes this thing which is
	irrecv.enableIRIn();
When I comment this line the code works totally fine!
Steps I followed:
Wrote code for running bot in various directions which worked perfectly.
Wrote code to get values of buttons when they're pressed using IRremote.h library which worked perfectly.
Merged code but one motor stopped working.
Here's my full code
#include<IRremote.h>
// Motor Driver
#define EN2 3           // Enable pin 2
#define RM1 4           // Front Right Motor
#define RM2 5           // Rear Right Motor
#define EN1 6           // Enable pin 1
#define LM1 7           // Front Left Motor
#define LM2 8           // Rear Left Motor
#define speedEN1 150
#define speedEN2 150
int RECV_PIN = 9;
IRrecv irrecv(RECV_PIN);
decode_results results;
unsigned long key_value = 0;
void forward()
	Serial.print("Forwards Triggered");
	digitalWrite(RM1,HIGH);
	digitalWrite(RM2,LOW);
	analogWrite(EN2,speedEN2);
	digitalWrite(LM1,HIGH);
	digitalWrite(LM2,LOW);
	analogWrite(EN1,speedEN1);
void right(){
	Serial.print("Right Triggered");
	digitalWrite(RM1,LOW);
	analogWrite(EN2,0);
void left(){
	digitalWrite(LM1,LOW);
	analogWrite(EN1,0);
void spin_left(){
	digitalWrite(LM2,HIGH);
void spin_right(){
void backward()
	Serial.print("Reverse Triggered");
	digitalWrite(RM2,HIGH);
void stop_all()
// 	Serial.print("Right Triggered");
	analogWrite(EN1,0);
	analogWrite(EN2,0);
void deg360()
	// MOTOR AND ENABLES
	pinMode (RM1, OUTPUT);
	pinMode (RM2, OUTPUT);
	pinMode (LM1, OUTPUT);
	pinMode (LM2, OUTPUT);
	pinMode (EN1, OUTPUT);
	pinMode (EN2, OUTPUT);
	Serial.println("Starting IR");
	irrecv.enableIRIn(); // when I comment out this line and receiver code forward function works perfectly
	Serial.println("Started IR");
  if (irrecv.decode(&results)) {
    Serial.println(results.value,HEX);
    if (results.value == 0XFFFFFFFF)
      results.value = key_value;
    switch (results.value) {
      case 0xFF629D:
        forward();
        // Serial.println("Working forward");
    key_value = results.value;
    irrecv.resume();
    delay(100);
hard to make any comment without seeing the earlier programs where both motors work
using sub-functions to control direction and speed of each motor would make the code easier to read. don't understand why you treat code 0xFFFFFFFF as a special case a instead of just ignoring it.
This code works:
// Motor Driver
int RECV_PIN = 9;
void forward()
void right(){
	analogWrite(EN2,0);
void left(){
	analogWrite(EN1,0);
void spin_left(){
void spin_right(){
void backward()
void stop_all()
	analogWrite(EN1,0);
	analogWrite(EN2,0);
void deg360()
	// irrecv.enableIRIn(); // when I comment out this line and receiver code forward function works perfectly
  forward();
On repeated button press it gives reading as 0xFFFFFFFF. So to handle that case I have used the if statement.
After googling a bit, I found out that pin number 3 is used by that IR sensor for some timer purpose. I am literally unaware about concepts so please bear with me. That pin number 3 is exactly the pin where I have connected my enable pin of right motor which stops working when I merge the code. Do you know anything about this? Can you help me out of this? Simplest solution would be to change that pin 3 to some other pin, but is there any other solution?
if the IR library uses the pin, not sure what you can do except use a different pin.
you could try the following code to verify that your code without the IR commands functions properly using single character commands entered thru the serial monitor
#undef IR
#ifdef IR
# include<IRremote.h>
#endif
// Motor Driver
#ifdef IR
int RECV_PIN = 9;
#endif
void forward()
void right(){
    	analogWrite(EN2,0);
void left(){
    	analogWrite(EN1,0);
void spin_left(){
void spin_right(){
void backward()
void stop_all()
    	analogWrite(EN1,0);
    	analogWrite(EN2,0);
void deg360()
#ifdef IR
#endif
    if (Serial.available ())
        switch (Serial.read ())  {
        case 'f':
            forward ();
        case 'r':
            right ();
        case 'l':
            left ();
        case 'b':
            backward ();
        case 'R':
            spin_right ();
        case 'L':
            spin_left ();
        case 'S':
            stop_all ();
        case '3':
            deg360 ();
        default:
#ifdef IR
            case 0xFF629D:
            forward();
        irrecv.resume();
        delay(100);
#endif
obviously you could use a similar switch statement for each IR code, simply ignoring 0xFFFFFFFF
I would like to see this information that talks about this use of pin 3 .
Can post the link
RV mineirin
This helps but the code does not work properly when merged.
here it is https://www.douban.com/note/542007770/
Translating the page would help.
can't comment w/o seeing the "merged" code
I meant the code you provided with works fine! The one I have clipped in question is merged code which does not work.
