Having trouble uploading sketch to pro mini using MacBook
I am using a MacBook running High Sierra version 10.13.6
I have a arduino pro mini hooked into the USB port
With a USB cable and a CP2102 adapter.
The settings are:
Board:”Arduino Pro or Pro Mini”
Processors: “Atmega328P (5V, 16 MHz)”
Programmer: “ArduinoISP”
The only ports I see available are:
/dev/cu.Bluetooth-Incoming-Port
/dev/cu.iPhone-WirelessiAPv2
I downloaded the virtual com port and restarted the Mac but still no other ports show up.
Little Help?
Make sure the USB cable is fully inserted into the CP2102 and the computer.
You may have a defective or charge-only USB cable. Try a different cable.
