I can't figure out what I am doing wrong - I have been referring to the data sheet and examples of setting up ADXL345 interrupts.
But my test LED on digital pin 8 does not seem to be firing in response to the interrupt signal from the ADXL345 INT1 going to arduino mega pin 2.
The full code (ino and modified ADXL345 library) are attached but I will point out the key functions I am using first:
My ISR function in my .ino:
void freeFall(void)
digitalWrite(8, nLED);
if (nLED == HIGH)
nLED = LOW;
nLED = HIGH;
Setup function:
void setup(void)
Serial.println("Accelerometer Test"); Serial.println("");
/* Initialise the sensor */
if(!accel.begin())
/* There was a problem detecting the ADXL345 ... check your connections */
Serial.println("Ooops, no ADXL345 detected ... Check your wiring!");
while(1);
/* Set the range to whatever is appropriate for your project */
accel.setRange(ADXL345_RANGE_16G);
// displaySetRange(ADXL345_RANGE_8G);
// displaySetRange(ADXL345_RANGE_4G);
// displaySetRange(ADXL345_RANGE_2G);
/* Display some basic information on this sensor */
displaySensorDetails();
/* Display additional settings (outside the scope of sensor_t) */
displayDataRate();
displayRange();
Serial.println("");
[b]accel.setADXL345FreeFallIntFunc(0, &freeFall, ADXL345_PIN_1);[/b]
Function setADXL345FreeFallIntFunc(0, &freeFall, ADXL345_PIN_1)
void Adafruit_ADXL345_Unified::setADXL345FreeFallIntFunc(uint8_t nArduinoIntNo, isr_func_ptr_type pIntFunc, pin_t nADXL345IntPin)
// Create an Arduino interrupt.
attachInterrupt(nArduinoIntNo, pIntFunc, RISING);
// Map the interrupt function to an ADXL345 interrupt pin.
if (nADXL345IntPin == ADXL345_PIN_1)
writeRegister(ADXL345_REG_INT_MAP, ~ADXL345_FUNC_FREEFALL);
else if (nADXL345IntPin == ADXL345_PIN_2)
writeRegister(ADXL345_REG_INT_MAP, ADXL345_FUNC_FREEFALL);
// Set the range to 16g
// Set the free fall threshold g
setFreeFallThreshold(ADXL345_FREEFALL_450mg);
// Set the free fall time
setFreeFallTime(ADXL345_FREEFALL_200ms);
// Enable the ADXL345 function and interrupt.
writeRegister(ADXL345_REG_INT_ENABLE, ADXL345_FUNC_FREEFALL);
Added enums in my modified ADXL345 library (so I don't have to remember which bit goes where for all the registers):
/* Used with register 0x31 (ADXL345_REG_DATA_FORMAT) to set g range */
typedef enum
ADXL345_RANGE_16G = 0b11, // +/- 16g
ADXL345_RANGE_8G = 0b10, // +/- 8g
ADXL345_RANGE_4G = 0b01, // +/- 4g
ADXL345_RANGE_2G = 0b00 // +/- 2g (default value)
} range_t;
/* Interrupt functions */
typedef enum
ADXL345_FUNC_FREEFALL = 0b00000100, // 4
ADXL345_FUNC_INACTIVITY = 0b00001000, // 8
ADXL345_FUNC_ACTIVITY = 0b00010000, // 16
ADXL345_FUNC_SINGLE_TAP = 0b00100000, // 32
ADXL345_FUNC_DOUBLE_TAP = 0b01000000, // 64
ADXL345_FUNC_SINGLE_DOUBLE_TAP = 0b01100000 // 96
function_t;
/* ADXL345 interrupt pins */
typedef enum
ADXL345_PIN_1 = 0b00000001, // INT 1
ADXL345_PIN_2 = 0b00000010 // INT 2
pin_t;
/* Thresholds */
typedef enum
ADXL345_THRESHOLD_1G = 0x0F,
ADXL345_THRESHOLD_2G = 0x1F,
ADXL345_THRESHOLD_3G = 0x3E,
ADXL345_THRESHOLD_4G = 0x3F,
ADXL345_THRESHOLD_5G = 0x4E,
ADXL345_THRESHOLD_6G = 0x9E,
ADXL345_THRESHOLD_7G = 0xAD,
ADXL345_THRESHOLD_8G = 0x7F,
ADXL345_THRESHOLD_9G = 0x8E,
ADXL345_THRESHOLD_10G = 0x9E,
ADXL345_THRESHOLD_11G = 0xAD,
ADXL345_THRESHOLD_12G = 0xBE,
ADXL345_THRESHOLD_13G = 0xCD,
ADXL345_THRESHOLD_14G = 0xDD,
ADXL345_THRESHOLD_15G = 0xEC,
ADXL345_THRESHOLD_16G = 0xFF
tap_threshold_t;
/* Duration */
typedef enum
ADXL345_DURATION_DISABLE = 0b00000000,
ADXL345_DURATION_625us = 0b00000001,
ADXL345_DURATION_1250us = 0b00000010,
ADXL345_DURATION_2500us = 0b00000100,
ADXL345_DURATION_5ms = 0b00001000,
ADXL345_DURATION_10ms = 0b00010000,
ADXL345_DURATION_20ms = 0b00100000,
ADXL345_DURATION_40ms = 0b01000000,
ADXL345_DURATION_80ms = 0b10000000
tap_duration_t;
/* Window & Latency */
typedef enum
ADXL345_WINLAT_DISABLE = 0b00000000,
ADXL345_WINLAT_1p25ms = 0b00000001,
ADXL345_WINLAT_2p5ms = 0b00000010,
ADXL345_WINLAT_5ms = 0b00000100,
ADXL345_WINLAT_10ms = 0b00001000,
ADXL345_WINLAT_20ms = 0b00010000,
ADXL345_WINLAT_40ms = 0b00100000,
ADXL345_WINLAT_80ms = 0b01000000,
ADXL345_WINLAT_160ms = 0b10000000,
ADXL345_WINLAT_318ms = 0b11111111,
tap_window_latency_t;
typedef enum
ADXL345_AXIS_DISABLE = 0b0000,
ADXL345_AXIS_Z = 0b0001,
ADXL345_AXIS_Y = 0b0010,
ADXL345_AXIS_X = 0b0100,
ADXL345_AXIS_SUPPRESS = 0b1000, // Suppress double tap if acceleration is greater than threshold
axis_t;
/* Free fall threshold */
typedef enum
ADXL345_FREEFALL_300mg = 0b00000101,
ADXL345_FREEFALL_375mg = 0b00000110,
ADXL345_FREEFALL_450mg = 0b00000111,
ADXL345_FREEFALL_525mg = 0b00001000,
ADXL345_FREEFALL_600mg = 0b00001001,
freefall_threshold_t;
/* Free fall time */
typedef enum
ADXL345_FREEFALL_100ms = 0b00010100,
ADXL345_FREEFALL_150ms = 0b00011110,
ADXL345_FREEFALL_200ms = 0b00101000,
ADXL345_FREEFALL_250ms = 0b00110010,
ADXL345_FREEFALL_300ms = 0b00111100,
ADXL345_FREEFALL_350ms = 0b01000110
freefall_time_t;
Adafruit_ADXL345_U.cpp (12.3 KB)
Adafruit_ADXL345_U.h (12.8 KB)
sensortest.ino (4.69 KB)
