I've assembled the project at
Reddit - Dive into anything and have run into a snag getting it to compile. Incidentally, it does compile for different boards such as the uno.
the code is as follows...
#include <Rtc_Pcf8563.h>
#include <Encoder.h>
#include <Wire.h>
#define HOURPIN 1
#define MINSECPIN 0
#define APIN A7
#define BPIN A6
#define BUTTON A5
Encoder encoder(APIN,BPIN);
Rtc_Pcf8563 rtc;
Adafruit_NeoPixel hourStrip = Adafruit_NeoPixel(80, HOURPIN, NEO_GRB + NEO_KHZ800);
Adafruit_NeoPixel minSecStrip = Adafruit_NeoPixel(120, MINSECPIN, NEO_GRB + NEO_KHZ800);
boolean buttonReleased = true;
int state = 0; //0=normal, 1=set second, 2=set minute, 3=set hour, 4=set brightness
int tic = 0, second = 0, minute = 5, hour = 3;
int minSecColor = 100, hourColor =50, brightness = 50;
long oldPos = 0, newPos = 0, oldTime=0;
pinMode(3, INPUT);
hourStrip.begin();
minSecStrip.begin();
hourStrip.setBrightness(brightness);
minSecStrip.setBrightness(brightness);
hourStrip.show(); // Initialize all pixels to 'off'
minSecStrip.show(); // Initialize all pixels to 'off'
for(int i=0; i<hourStrip.numPixels(); i++) {
hourStrip.setPixelColor(i, Wheel((i+hourColor) & 255));
for(int i=0; i<minSecStrip.numPixels(); i++) {
minSecStrip.setPixelColor(i, Wheel((i+minSecColor) & 255));
hourStrip.show();
minSecStrip.show();
rtc.initClock();
rtc.setDate(14,6,3,0,10);//day, weekday, month, century, year
rtc.setTime(3,5,10); //hr, min, sec
rtc.setSquareWave(130); //sets to 32Hz square wave: format is 0b10000010 - bit 7 enables CLKOUT and bit 1:0 sets the frequency (00=32.768kHz, 01=1024Hz, 10=32Hz, 11=1Hz)
//attachInterrupt(3, tick, FALLING); //Attach 32Hz clock signal to our main clock function
if(buttonReleased) {
//Check if button has been newly pressed
if(digitalRead(BUTTON) == LOW) { //User wants to advance to the next state
state++;
buttonReleased = false;
if(state==5) {
state = 0;
rtc.setTime(hour, minute, second); //hr, min, sec
} else if(digitalRead(BUTTON)==HIGH) {buttonReleased = true; }//Button has been released
//State 0: Normal clock stuff
tick(); //Done on 32Hz interrupt
if(state!=0) { //Set all pixels to dark since we're setting something. We put this here so we don't repeat code
minSecStrip.setPixelColor(i, 0);
hourStrip.setPixelColor(i, 0);
//State 1: Set Second
if(state==1) {
newPos = encoder.read();
if(newPos!=oldPos) {
second += (newPos-oldPos);
oldPos = newPos;
if(second>59){ second -=60; }
if(second<0){ second +=60; }
minSecStrip.setPixelColor(minute*2, 100, 100, 100);
minSecStrip.setPixelColor(minute*2+1, 100, 100, 100);
minSecStrip.setPixelColor(minute*2+2, 100, 100, 100);
minSecStrip.setPixelColor(minute*2+3, 100, 100, 100);
minSecStrip.setPixelColor(second*2, 255, 10, 255);
minSecStrip.setPixelColor(second*2+1, 255, 10, 255);
minSecStrip.setPixelColor(second*2+2, 255, 10, 255);
hourStrip.setPixelColor((hour*hourStrip.numPixels()/12), 200, 200, 200);
hourStrip.setPixelColor((hour*hourStrip.numPixels()/12)+1, 200, 200, 200);
hourStrip.setPixelColor((hour*hourStrip.numPixels()/12)+2, 200, 200, 200);
hourStrip.setPixelColor((hour*hourStrip.numPixels()/12)+3, 200, 200, 200);
//State 2: Set Minute
if(state==2) {
minute += (newPos-oldPos);
oldPos = newPos;
if(minute>59){ minute -=60; }
if(minute<0){ minute +=60; }
minSecStrip.setPixelColor(second*2, 100, 100, 100);
minSecStrip.setPixelColor(second*2+1, 100, 100, 100);
minSecStrip.setPixelColor(second*2+2, 100, 100, 100);
minSecStrip.setPixelColor(minute*2, 255, 10, 255);
minSecStrip.setPixelColor(minute*2+1, 255, 10, 255);
minSecStrip.setPixelColor(minute*2+2, 255, 10, 255);
minSecStrip.setPixelColor(minute*2+3, 255, 10, 255);
//State 3: Set Hour
if(state==3) {
if(abs(newPos-oldPos)>3) {
hour += (newPos-oldPos)/3;
oldPos = newPos;
if(hour>11) { hour -=12; }
if(hour<0) { hour +=12; }
minSecStrip.setPixelColor(second*2, 200, 200, 200);
minSecStrip.setPixelColor(second*2+1, 200, 200, 200);
minSecStrip.setPixelColor(second*2+2, 200, 200, 200);
minSecStrip.setPixelColor(minute*2, 200, 200, 200);
minSecStrip.setPixelColor(minute*2+1, 200, 200, 200);
minSecStrip.setPixelColor(minute*2+2, 200, 200, 200);
minSecStrip.setPixelColor(minute*2+3, 200, 200, 200);
hourStrip.setPixelColor((hour*hourStrip.numPixels()/12), 255, 10, 255);
hourStrip.setPixelColor((hour*hourStrip.numPixels()/12)+1, 255, 10, 255);
hourStrip.setPixelColor((hour*hourStrip.numPixels()/12)+2, 255, 10, 255);
hourStrip.setPixelColor((hour*hourStrip.numPixels()/12)+3, 255, 10, 255);
//State 4: Set Brightness
if(state==4) {
brightness -= (newPos-oldPos);
oldPos = newPos;
if(brightness>254) { brightness = 254; }
if(brightness<1) { brightness = 1; }
minSecStrip.setPixelColor(i, 255, 255, 255);
hourStrip.setPixelColor(i, 255, 255, 255);
hourStrip.show();
minSecStrip.show();
void tick() {//Do clock stuff at 32Hz; For some reason it actually does this at 64Hz, I'm not sure why...
if(state==0) {
//Advance 32Hz tick (actually 64Hz for some reason) and do second/minute/hour advances
while(digitalRead(3)==LOW) {} //wait for rising edge of clock
tic++;
if(tic==32){
//if((millis()-oldTime)>=472) { //Substitue timer for RTC since it isn't working yet
// oldTime = millis();
tic = 0;
second--;
if(second==-1) {
second = 119;
minute--;
if(minute==-1) {
minute = 59;
hour--;
if(hour==-1){ hour = 11;}
minSecStrip.setPixelColor(i, Wheel((i+i+minSecColor) & 255));
minSecStrip.setPixelColor(second, 0, 0, 0);
minSecStrip.setPixelColor(second+1, 128, 128, 128);
minSecStrip.setPixelColor(second+2, 0, 0, 0);
minSecStrip.setPixelColor(minute*2, 0, 0, 0);
minSecStrip.setPixelColor(minute*2+1, 255, 255, 255);
minSecStrip.setPixelColor(minute*2+2, 255, 255, 255);
minSecStrip.setPixelColor(minute*2+3, 0, 0, 0);
minSecColor++;
if(minSecColor>255) minSecColor = 0;
minSecStrip.show();
hourStrip.setPixelColor(i, Wheel((hourColor) & 255));
hourStrip.setPixelColor((hour*hourStrip.numPixels()/12), 0, 0, 0);
hourStrip.setPixelColor((hour*hourStrip.numPixels()/12)+4, 200, 200, 200);
hourStrip.setPixelColor((hour*hourStrip.numPixels()/12)+5, 0, 0, 0);
hourColor--;
if(hourColor==0) hourColor = 256;
hourStrip.show();
// Input a value 0 to 255 to get a color value.
// The colours are a transition r - g - b - back to r.
uint32_t Wheel(byte WheelPos) {
if(WheelPos < 85) {
return hourStrip.Color(WheelPos * 3, 255 - WheelPos * 3, 0);
} else if(WheelPos < 170) {
WheelPos -= 85;
return hourStrip.Color(255 - WheelPos * 3, 0, WheelPos * 3);
WheelPos -= 170;
return hourStrip.Color(0, WheelPos * 3, 255 - WheelPos * 3);
I downloaded the arduino board definition from
and loaded it into my arduino IDE. I also downloaded the libraries for the ws2812b, the RTC, and the encoder. I used the encoder library from
https://www.pjrc.com/teensy/td_libs_Encoder.html
but when I go to compile it (with board set to Mighty 1284p using optiboot) i get the following errors...
This report would have more information with "Show verbose output during compilation" enabled in File > Preferences.
Arduino: 1.0.6 (Windows 7), Board: "Mighty 1284p 16MHz using Optiboot" In file included from C:\Users\dataylor\Documents\Arduino\libraries\Encoder/Encoder.h:46, from clock.ino:2:
C:\Users\dataylor\Documents\Arduino\libraries\Encoder/utility/interrupt_pins.h:153:2: error: #error "Interrupts are unknown for this board, please add to this code"
C:\Users\dataylor\Documents\Arduino\libraries\Encoder/utility/interrupt_pins.h:156:2: error: #error "Encoder requires interrupt pins, but this board does not have any :("
C:\Users\dataylor\Documents\Arduino\libraries\Encoder/utility/interrupt_pins.h:157:2: error: #error "You could try defining ENCODER_DO_NOT_USE_INTERRUPTS as a kludge."
In file included from clock.ino:2:
C:\Users\dataylor\Documents\Arduino\libraries\Encoder/Encoder.h:135: error: 'CORE_NUM_INTERRUPT' was not declared in this scope
I think it has to do with the interrupt_pins file in the encoder library. Any help would be greatly appreciated.
