Having trouble with analogWrite
Problem: The Ir LED isn’t getting power. It’s not being picked up by the IR sensor. When replace with an LED it didn’t light up and the LED wasn’t blown.
Code:
#include <IRremote.h>
#define E2 82.41
#define E3 164.81
#define first_key 3360
#define firing 100
int speaker = 10;
int ch1;
int points = 0;
int receiver_pin = 8;
int fire = 99;
int first_led_pin = 7;
int ir_led_pin = 11;
int third_led_pin = 5;
int fourth_led_pin = 4;
int yellow_led_pin = 3;
int green_led_pin = 2;
int led[] = {0,0,0,0};
IRrecv receiver(receiver_pin);
decode_results output;
//Setup for Outputs and Inputs
receiver.enableIRIn();
pinMode (speaker, OUTPUT);
pinMode(9, OUTPUT);
pinMode(A1, INPUT);
pinMode(first_led_pin, OUTPUT);
pinMode(ir_led_pin, OUTPUT);
pinMode(third_led_pin, OUTPUT);
pinMode(fourth_led_pin, OUTPUT);
pinMode (yellow_led_pin, OUTPUT);
pinMode(green_led_pin, OUTPUT);
digitalWrite(first_led_pin, HIGH);
digitalWrite(green_led_pin, HIGH);
digitalWrite(yellow_led_pin, HIGH);
digitalWrite(fourth_led_pin, HIGH);
digitalWrite(third_led_pin, HIGH);
ch1 = pulseIn(A1, HIGH, 25000);
Serial.print("Channel 1:");
Serial.println(ch1);
if (fire>25){ //Stop shooting after 25 senses
analogWrite(ir_led_pin, 0);
if (ch1 > 1300 && fire == firing){ //Only fire when 100 senses have gone by and when joystick is up
analogWrite(ir_led_pin, 51);
tone(speaker, E2, 1000);
fire = 0;
if (receiver.decode(&output)) {
unsigned int value = output.value;
if (value >0) {
points ++; //Points for 4 lives
switch (points){
case 1:
digitalWrite(green_led_pin, LOW);
case 2:
digitalWrite(yellow_led_pin, LOW);
case 3:
digitalWrite(fourth_led_pin, LOW);
case 4: //Infinite loop for death
while (points == 4){
digitalWrite(third_led_pin, LOW);
digitalWrite(first_led_pin, LOW);
delay(100);
delay(100);
for(i=0;i<10;i++){ //Getting hit shield and flashing lights
for(i=0; i<3; i++){
Serial.println(value);
receiver.resume();
if (fire < firing){ //Says 1 loop has gone by from since it shot until reload time is over
fire++;}
I can post pics if anyone wants them.
Please read the forum sticky post to find out how to post code correctly and what other things you need to include in your post in order for us to be able to help you.
First of all, I suggest that you remove all code that is not relevant to the problem; write a simple test sketch. That will allow you to concentrate on the problem
Next give a description of what you expect your (new) code to do and what it does / doesn't do.
