UPDATE
I tried uploading a new sketch I found online.
// Example program for the MD_DS1307 library
// Allows testing of all library functions and RTC chip from the Serial Monitor.
#include <MD_DS1307.h>
#include <Wire.h>
#define PRINTS(s) Serial.print(F(s));
#define PRINT(s, v) { Serial.print(F(s)); Serial.print(v); }
Serial.begin(57600);
PRINTS("[MD_DDS1307_Test]");
usage();
void usage(void)
PRINTS("\n?\thelp - this message");
PRINTS("\n\ntr\tread the current time");
PRINTS("\ntw yyyymmdd hhmmss dw\twrite the current date, time and day of week (1-7)");
PRINTS("\n\nrr\tread the contents of RAM buffer");
PRINTS("\nrw aa nn vv [vv...]\twrite RAM address hex aa with nn hex values vv");
PRINTS("\n\ns\tstatus of the RTC");
PRINTS("\nd\tcalculate day of week from current date");
PRINTS("\n\nc n v\twrite the value v to status n, where n is");
PRINTS("\n\t0 - Clock Halt (n 0=run, 1=halt)");
PRINTS("\n\t1 - SQW Enable(n 0=halt, 1=run)");
PRINTS("\n\t2 - SQW Type (on) (n 1=1Hz, 2=4Mhz, 3=8Mhz, 4=32MHz)");
PRINTS("\n\t3 - SQW Type (off) (n 0=low, 1=high)");
PRINTS("\n\t4 - 12 hour mode (n 0=24h, 1=12h)\n");
const char *dow2String(uint8_t code)
static const char *str[] = { "---", "Sun", "Mon", "Tue", "Wed", "Thu", "Fri", "Sat" };
return(str
const char *ctl2String(uint8_t code)
"CLOCK_HALT",
"SQW_RUN",
"SQW_TYPE_ON",
"SQW_TYPE_OFF",
"12H MODE"
return(str[code]);
const char *sts2String(uint8_t code)
"ERROR",
"ON",
"OFF",
"1Hz",
"4KHz",
"8KHz",
"32KHz",
"HIGH",
"LOW"
return(str[code]);
uint8_t htoi(char c)
c = toupper(c);
if (c >= '0' && c <= '9')
return(c - '0');
else if (c >= 'A' && c <= 'F')
return(c - 'A' + 10);
return(0);
uint8_t i2dig(uint8_t mode)
// input 2 digits in the specified base
uint8_t v = 0;
char c[3] = { "00" };
c[0] = ReadNext();
c[1] = ReadNext();
switch (mode)
case DEC: v = atoi(c); break;
case HEX: v = (htoi(c[0]) << 4) + htoi(c[1]); ; break;
return(v);
char htoa(uint8_t i)
if (i >= 0 && i <= 9)
return(i + '0');
if (i >= 10 && i <= 15)
return(i - 10 + 'a');
return('?');
const char *p2dig(uint8_t v, uint8_t mode)
// print 2 digits leading zero
uint8_t n = 0;
static char c[3] = { "00" };
switch(mode)
case HEX:
c[0] = htoa((v >> 4) & 0xf);
c[1] = htoa(v & 0xf);
case DEC:
c[0] = ((v / 10) % 10) + '0';
c[1] = (v % 10) + '0';
return(c);
void showStatus()
PRINT("\nClock Halt:\t", sts2String(RTC.status(DS1307_CLOCK_HALT)));
PRINT("\nIs running:\t", RTC.isRunning());
PRINT("\nSQW Output:\t", sts2String(RTC.status(DS1307_SQW_RUN)));
PRINT("\nSQW Type (on):\t", sts2String(RTC.status(DS1307_SQW_TYPE_ON)));
PRINT("\nSQW Type (off):\t", sts2String(RTC.status(DS1307_SQW_TYPE_OFF)));
PRINT("\n12h mode:\t", sts2String(RTC.status(DS1307_12H)));
void printTime()
PRINT("", RTC.yyyy);
PRINT("-", p2dig(RTC.mm, DEC));
PRINT("-", p2dig(RTC.dd, DEC));
PRINT(" ", p2dig(RTC.h, DEC));
PRINT(":", p2dig(RTC.m, DEC));
PRINT(":", p2dig(RTC.s, DEC));
if (RTC.status(DS1307_12H) == DS1307_ON)
PRINT(" ", RTC.pm ? "pm" : "am");
PRINT(" ", dow2String(RTC.dow));
void showTime()
RTC.readTime();
PRINTS("\n");
printTime();
void showRAM()
#define MAX_READ_BUF (DS1307_RAM_MAX / 8) // do 8 lines
uint8_t buf[MAX_READ_BUF];
for (int i=0; i<DS1307_RAM_MAX; i+=MAX_READ_BUF)
RTC.readRAM(i, buf, MAX_READ_BUF);
PRINT("\n", p2dig(i, HEX));
PRINTS(":");
for (int j = 0; j < MAX_READ_BUF; j++)
PRINT(" ", p2dig(buf[j], HEX));
PRINTS(" ");
for (int j=0; j<MAX_READ_BUF; j++)
if (isalnum(buf[j]) || ispunct(buf[j]))
PRINT(" ", (char)buf[j]);
PRINTS(" .");
void writeRAM()
uint8_t addr = i2dig(HEX);
uint8_t len = i2dig(HEX);
uint8_t val[DS1307_RAM_MAX];
if ((len == 0) || (len > DS1307_RAM_MAX))
PRINTS("\nInvalid data length");
return;
for (int i=0; i<len; i++)
val[i] = i2dig(HEX);
PRINT("\nAddress 0x", p2dig(addr, HEX));
PRINTS(" write value");
PRINT(" ", p2dig(val[i], HEX));
PRINT("\n", RTC.writeRAM(addr, val, len));
PRINTS(" bytes written");
void showDoW(void)
RTC.readTime();
PRINT("\nCalculated DoW is ", dow2String(RTC.calcDoW(RTC.yyyy, RTC.mm, RTC.dd)));
void writeTime()
RTC.yyyy = i2dig(DEC)*100 + i2dig(DEC);
RTC.mm = i2dig(DEC);
RTC.dd = i2dig(DEC);
RTC.h = i2dig(DEC);
RTC.m = i2dig(DEC);
RTC.s = i2dig(DEC);
RTC.dow = i2dig(DEC);
PRINTS("\nWriting ");
printTime();
RTC.writeTime();
void writeControl()
char c = ReadNext();
uint8_t item, value;
switch (c)
case '0': // halt
item = DS1307_CLOCK_HALT;
c = ReadNext();
switch (c)
case '0': value = DS1307_OFF; break;
case '1': value = DS1307_ON; break;
default: goto error;
case '1': // enable
item = DS1307_SQW_RUN;
c = ReadNext();
switch (c)
case '2': // type on
item = DS1307_SQW_TYPE_ON;
c = ReadNext();
switch (c)
case '1': value = DS1307_SQW_1HZ; break;
case '2': value = DS1307_SQW_4KHZ; break;
case '3': value = DS1307_SQW_8KHZ; break;
case '4': value = DS1307_SQW_32KHZ; break;
case '3': // type off
item = DS1307_SQW_TYPE_OFF;
c = ReadNext();
switch (c)
case '0': value = DS1307_SQW_LOW; break;
case '1': value = DS1307_SQW_HIGH; break;
case '4': // 12 h mode
item = DS1307_12H;
c = ReadNext();
switch (c)
default:
error:
PRINTS("\nBad control element or parameter");
return;
// do it
PRINT("\nControlling ", ctl2String(item));
PRINT(" value ", sts2String(value));
RTC.control(item, value);
return;
char ReadNext()
// Read the next character from the serial input stream, skip whitespace.
// Busy loop with a delay.
char c;
do
while (!Serial.available())
delay (50); // wait for the next character
c = Serial.read();
} while (isspace(c));
return(c);
char c;
// we need to get the next character to know what command we want to process
c = ReadNext();
switch (toupper(c))
case '?': usage(); break;
// Status and control
case 'S': showStatus(); break;
case 'C': writeControl(); break;
case 'D': showDoW(); break;
// Time functions
case 'T': // Display updates
c = ReadNext();
switch (toupper(c))
case 'R': showTime(); break;
case 'W': writeTime(); break;
default: goto no_good;
// RAM functions
case 'R': // Display updates
c = ReadNext();
switch (toupper(c))
case 'R': showRAM(); break;
case 'W': writeRAM(); break;
default: // don't know what to do with this!
no_good: // label for default escape when we can't process a character
PRINT("\nBad parameter '", Serial.print(c));
PRINTS("'");
while (Serial.available()) // flush the buffer
c = ReadNext();
PRINTS("\n");
Here's the result.
[IMG]http://i64.tinypic.com/33mq2ci.png[/IMG]
Why is that on the other sketch, nothings appearing on the serial monitor?
