Having trouble with FreqPeriodCounter.h
I am trying to get a frequency reading off pin 5 of an Arduino Uno r3 using FreqPeriodCounter.h. The code as stands will not compile. Can someone look at it and tell me what I am doing wrong?
This is the error message Arduino generates.
sketch_aug26a:7: error: no matching function for call to 'FreqPeriodCounter::FreqPeriodCounter(int, long unsigned int (&)())'
C:\Documents and Settings\Mark Tiede\My Documents\Arduino\libraries\FreqPeriodCounter/FreqPeriodCounter.h:20: note: candidates are: FreqPeriodCounter::FreqPeriodCounter(byte, long unsigned int (*)(), unsigned int)
C:\Documents and Settings\Mark Tiede\My Documents\Arduino\libraries\FreqPeriodCounter/FreqPeriodCounter.h:18: note: FreqPeriodCounter::FreqPeriodCounter(const FreqPeriodCounter&)
sketch_aug26a:26: error: expected unqualified-id before '{' token
#include <LiquidCrystal.h>
#include <FreqPeriodCounter.h>
LiquidCrystal lcd(11, 10, A5, 4, 3, 2);
const byte freqPin = 5;
FreqPeriodCounter counter(freqPin, millis);
// setup the pins to be used
    lcd.begin(16,2);
    lcd.noCursor();
    lcd.clear();
//////MAIN LOOP\\\\\\\
        tempolcd();
///////functions\\\\\\\\\
void tempolcd()
    counter.poll();
    float freq = (float)1 / counter.period;
    lcd.setCursor(0,1);  // Set cursor to column 1, row 2.
    lcd.print("TEMPO ");  // Printing TEMPO to the LCD screen.
    lcd.setCursor(6,1);  // Set cursor to column 7, row 2.
    lcd.print(freq);  // Display TEMPO time to LCD screen.
Thanks,
Bruce
That's old code that's not compatible with newer IDE versions.
Try adding
#include <Arduino.h>
Up top.
GoForSmoke:
Try adding
Up top.
That did not fix the issue.
That was a guess at a quick and easy, and I was in a hurry.
Looking at the code and the error messages -maybe- the compiler has trouble with what appears to be an undeclared variable named millis. Try;
FreqPeriodCounter counter(freqPin, millis());
or
unsigned long millis = millis();
