Hello guys! Im new at arduino. Im pursuing a project title Home automation with Arduino MEGA2560, 8 Channel Relay, and HM-10 bluetooth module.
I'm having a trouble with my bluetooth HM-10. Im using Samsung A5 with Android version 4.4.4.
I had uploaded the program below:
Please note as I have used the android app you told , the string inputs are taken as
A,B,C,D,E,F,G and a,b,c,d,e,f,g.
I have also written code for voice on and off which has all on and all off function
but since the android app we are using dosent have such key so i didnt took them
String inputs;
#define relay1 38 //Connect relay1 to pin 9
#define relay2 40 //Connect relay2 to pin 8
#define relay3 42 //Connect relay3 to pin 7
#define relay4 44 //Connect relay4 to pin 6
#define relay5 46 //Connect relay5 to pin 5
#define relay6 48 //Connect relay6 to pin 4
#define relay7 50 //Connect relay7 to pin 3
#define relay8 52 //Connect relay8 to pin 2
Serial.begin(9600); //Set rate for communicating with phone
Serial1.begin(9600);
pinMode(relay1, OUTPUT); //Set relay1 as an output
pinMode(relay2, OUTPUT); //Set relay2 as an output
pinMode(relay3, OUTPUT); //Set relay1 as an output
pinMode(relay4, OUTPUT); //Set relay2 as an output
pinMode(relay5, OUTPUT); //Set relay1 as an output
pinMode(relay6, OUTPUT); //Set relay2 as an output
pinMode(relay7, OUTPUT); //Set relay1 as an output
pinMode(relay8, OUTPUT); //Set relay2 as an output
digitalWrite(relay1, LOW); //Switch relay1 off
digitalWrite(relay2, LOW); //Swtich relay2 off
digitalWrite(relay3, LOW); //Switch relay1 off
digitalWrite(relay4, LOW); //Swtich relay2 off
digitalWrite(relay5, LOW); //Switch relay1 off
digitalWrite(relay6, LOW); //Swtich relay2 off
digitalWrite(relay7, LOW); //Switch relay1 off
digitalWrite(relay8, LOW); //Swtich relay2 off
while(Serial.available()) //Check if there are available bytes to read
delay(10); //Delay to make it stable
char c = Serial.read(); //Conduct a serial read
if (c == '#'){
break; //Stop the loop once # is detected after a word
inputs += c; //Means inputs = inputs + c
if (inputs.length() >0)
Serial.println(inputs);
if(inputs == "A")
digitalWrite(relay1, HIGH);
else if(inputs == "a")
else if(inputs == "B")
digitalWrite(relay2, HIGH);
else if(inputs == "b")
else if(inputs == "C")
digitalWrite(relay3, HIGH);
else if(inputs == "c")
else if(inputs == "D")
digitalWrite(relay4, HIGH);
else if(inputs == "d")
else if(inputs == "E")
digitalWrite(relay5, HIGH);
else if(inputs == "e")
else if(inputs == "F")
digitalWrite(relay6, HIGH);
else if(inputs == "f")
else if(inputs == "G")
digitalWrite(relay7, HIGH);
else if(inputs == "g")
else if(inputs == "H")
digitalWrite(relay8, HIGH);
else if(inputs == "h")
inputs="";
... i had connected by relay on pin 38,40,42,44,46,48,50,52.
My bluetooth HM-10 TXD is connected to
When i tried to connect my bluetooth HM-10 to my android phone, it says "Unable to connect. I had already paired with my android phone but still it is unable to connect.
Can you help me guys in determining my problem?
Thanks
