Having trouble with interrupts.
I am using an Arduino Demilanove and I want to use pins D9-D13 as 5 interrupt lines.
My code currently looks something like this
int mask = 0;
   PCICR |= (1 << PCIE0);
   PCMSK0 |= (1 <<PCINT1) | (1 <<PCINT2) | (1 <<PCINT3) | (1 <<PCINT4) | (1 <<PCINT5);
   interrupts();
ISR ( PCINT0_vect ) {
    mask = PORTB;
    Serial.println(mask,BIN);
I eventually want to use mask to mask out the PORTB bits to see what has set off the interrupt, but I am just simply monitoring the value using the serial monitor right now.
When I set off the interrupt on that pin, the serial monitor prints, but it prints all 0s. I am supplying a 1, then a 0. It only displays 0.
I am expecting it to output 10 since PB1 is the bit changing.
Anyone know what I am doing wrong?
I am not sure but, use byte data type for mask instead of int. Remove the interrupts() function as far as I know in Arduino interrupts enabled at background. Don't use delay and millis in interrupt vector.
